Hand Routing With An Edge Guide - Router Forums
 5Likes
post #1 of 14 (permalink) Old 11-12-2016, 07:46 AM Thread Starter
I have a 36 inch long x 10 inch wide board and will route a shallow groove down the middle. I have an edge guide for the router. Is there a preferred placement for the edge guide i.e. should it be right in front of me and 'pushed' against the near edge of the board as I move left to right OR should it be on the far side of the board and 'pulled' against the far edge of the board as I move right to left? Both edges of the board are straight and flat.
JIMMIEM is offline
post #2 of 14 (permalink) Old 11-12-2016, 08:54 AM
First Name: pat
A lot to be said about this early routing technique; it's been around for >60 years.
Pushing is better than pulling with edge guide routing; it's easier
(you have your body wt. working for you) and you can see the whole megillah.
(Also a clear view with the guide on the far side but you're slightly un-balanced pulling.)
Pushing and pulling (with an edge guide on both sides of the work) renders complete control.
Inside cuts are always done at risk. Relax the pull or push and the cutter goes where it wants to.
For precise slot widths use a cutter <the width, open the edge guides (introduce some slop) so the cutter pathway equals the desired width. This frees up the cutter, so when you plow down the middle of the slot the cutter can bend every which way and not be expressed. Now when you pull the edge guides home (against the work) you're only taking a small fraction of the cutter diameter in wood.
That will yield smooth accurate & precise walls.
DaninVan likes this.
Quillman is offline
post #3 of 14 (permalink) Old 11-12-2016, 09:29 AM
RainMan 2.0's Avatar
If you scroll down to the last post on Mikes thread , you can see how he made a cheap jig to guide the router for a perfect dado cut that is pretty much fool proof
He also made an adjustable version I thought , but for the life of me I can't find it .
An edge guide is just a recipe for disaster IMO .
http://www.routerforums.com/show-n-t...al-duplex.html
Link to Mikes thread ^^^
My grade four teacher told me he thought I was an idiot savant , minus the savant part
RainMan 2.0 is online now
post #4 of 14 (permalink) Old 11-12-2016, 09:46 AM
First Name: fire65
They covered it. And if you have it, practice on some scrap wood.
RainMan 2.0 and jj777746 like this.
fire65 is online now
post #5 of 14 (permalink) Old 11-12-2016, 11:38 AM
It's hard not to stray from the intended path. The guide stops you from moving inward but not outward. Pat's double guide is the only solution that will prevent that. Some of the OEM guides I've seen clamp onto the guide rods. Others are fixed onto the rods. You can make a crude but workable one of your own or modify an OEM by getting longer rods and fabricating an extra fence for it or buy that beauty that Pat makes.
Ray Newman likes this.
post #6 of 14 (permalink) Old 11-12-2016, 01:49 PM
That's great for crosscuts, Rick, but not practical for long lengths. For arguments sake, the two vertical channels to sink the pilaster strips into on bookcase gables.
Pilaster Strips - Lee Valley Tools
DaninVan is online now
post #7 of 14 (permalink) Old 11-12-2016, 02:00 PM
Nickp's Avatar
First Name: Nick
The one I made is just like Mike's but fully adjustable (I think pics are in my uploads...if not, I'll post a pic). I use it to route the tread slots for closed stringers or any time I need a slot at an angle to an edge.
EDIT...found the thread and pics...here they are...
http://www.routerforums.com/portable...ig-stairs.html
Nick
Points to Ponder...
LEARNING - the decision you make to know and
understand more about some thing.
TIME - the thing that gets in the way of learning.
Nickp is offline
post #8 of 14 (permalink) Old 11-12-2016, 03:20 PM
boogalee's Avatar
First Name: Al
Why not use your router table.
Al B
boogalee is offline
post #9 of 14 (permalink) Old 11-12-2016, 03:39 PM Thread Starter
I would normally do this on the router table. But I'm doing this on MDF which I really don't like having to route indoors so my plan is to do this routing outdoors. I haven't figured out a good way to capture the dust when doing this type of cut on the router table.
JIMMIEM is offline
post #10 of 14 (permalink) Old 11-12-2016, 03:41 PM
First Name: Ray
How wide and deep does this shallow groove need to be; does the bottom need to be flat??
Your profile shows that you have a table saw. Have a dado set? If you do have a dado set for your table saw, cut the groove with a dado cutter and feather boards to hold the work down on the table saw top and against the fence.
Or, if you have a rip blade that will cut a flat kerf bottom, use it to cut the groove and adjust the fence to the needed width. Again, use feather boards.
In my opinion and experience, there is far too much room for error/drift with a 36" long board and a hand held router, even with an edge guide. If you want to utilize a router, fabricate a guide with two runners to keep the router from wandering.
Ray Newman is online now
Human Verification
Edge Guide trapped workpiece? PHILRAY1957 Introductions 11 07-19-2016 03:14 PM
Edge guide iredvette General Routing 6 12-18-2014 09:09 AM
Router edge guide purchase imminent. Sominus General Routing 3 01-28-2014 12:16 PM
Edge Guide jfreeland Starting Off 14 07-28-2011 09:11 PM
Rockler Router Edge Guide reds_21 Jigs and Fixtures 1 02-06-2005 10:25 PM
