Juice groove in curved cutting board - Page 2 - Router Forums
 6Likes
post #11 of 12 (permalink) Old 11-21-2016, 05:23 PM
It looks like you used a straight bit for the groove Dean. My personal preference is a round nose bit. A rounded groove is easy to sand by getting a dowel rod the same radius as the bit and gluing a wrap of sandpaper on it. You can glue up several different dowels with different grits to speed things up.
post #12 of 12 (permalink) Old 12-20-2016, 05:10 PM
First Name: Eric
Originally Posted by Dean Cruse View Post
I saw that Bosch makes a roller bearing guide for the trim router..... It also seems like it might be a bit hard to control using this method. Anyone have any experience with these types of edge guides?
That type of guide is called something like a follow bearing guide and they were originally designed specifically for use with the non-bearing laminate trimming cutters we used to use in the dim and distant past. They are designed to sit directly below the cutter and there is a definite knack to using them - the bearing should be chosen to be of larger diameter than the cutter so that it isn't possible to take a chunk out of the workpiece (if you twist the router/trimmer around the bearing will stop the cutting action - this makes them very safe and economical for laminate trimming). In use it's a bit like the knack you develop for pencil scribing (coping in USA) an edge with a pair of compasses. What they really aren't designed to do is be offset from the cutter in the way your job would require. In that situation I cannot begin to see how you'd control the cut to get a nice smooth groove. As others have said, the best method will be a template, guide bush and a cutter although I wouldn't try going the guide bush in a slot idea as GBs tend to bind very easily if the slot is at all tight, and in any case how would you get a slot to go round the full perimeter of a board?
Added this post for information about the way in which these roller guide bearings are supposed to work
Job and Knock is offline
Human Verification
Groove and Tennon Joint Construction neville9999 General Routing 3 11-19-2013 11:15 AM
Cutting board and dovetail joinery rzaccone Table-mounted Routing 2 05-12-2006 11:14 AM
Just one more cutting board bobj3 Show N' Tell 2 04-04-2006 04:44 PM
Cutting Board woody Show N' Tell 3 04-02-2006 04:32 PM
