wide router bit - Router Forums
 16Likes
post #1 of 28 (permalink) Old 12-13-2016, 09:17 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
wide router bit
I'm using my router sled a lot to flatten small panels of wood, but I only have narrow cutters and its taking way too long to cover the surface. Is there a cutter that will "polish" wood to a width of 2" or thereabouts?
sunnybob is offline
post #2 of 28 (permalink) Old 12-13-2016, 10:35 AM
MikeMa's Avatar
I think most people use a 3/4"-1" straight bit for this purpose. A 2" router bit should only be used in a table.
Herb Stoops likes this.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #3 of 28 (permalink) Old 12-13-2016, 10:49 AM
Maybe one of these would speed er up. Mega Dado and Planer Bit - FineWoodworking
Herb Stoops is offline
post #4 of 28 (permalink) Old 12-13-2016, 11:38 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Herb, thats what I'm after.
Typical though, The uk branch of infinity is out of stock. I've emailed asking for a delivery date. Thanks very much
sunnybob is offline
post #5 of 28 (permalink) Old 12-13-2016, 12:34 PM
Bowl bits are usually a bit wider Bob and they have radiused corners so they are less likely to leave lap marks.
Semipro likes this.
post #6 of 28 (permalink) Old 12-13-2016, 12:49 PM
Wildman692's Avatar
First Name: Roger
sounds a tad dangerous to me, use a hand planer or jointer for the job.
Roger in the UK, helping animal rescue.
Wildman692 is offline
post #7 of 28 (permalink) Old 12-13-2016, 01:02 PM
Hope these aren't banned too.
post #8 of 28 (permalink) Old 12-13-2016, 01:04 PM
Hope you have a variable speed router motor as a slower speed might be required for this bit.
post #9 of 28 (permalink) Old 12-13-2016, 01:50 PM
It's a process that has been done many times by many people with great success Roger and is more accurate than a plane and often the pieces are far too wide to put on a jointer. I used a 1.5" straight bit from Lee Valley to level the work bench I made by laminating 2 bys together.
Last edited by Cherryville Chuck; 12-13-2016 at 07:48 PM. Reason: plane not planer
post #10 of 28 (permalink) Old 12-13-2016, 02:27 PM
Wildman692's Avatar
First Name: Roger
it seems everything is banned in the UK, ha ha. But only for commercial use of course.
Human Verification
Need help installing router bit avgjoesgym Router Bits - Types and Usage 23 11-08-2015 11:59 AM
Craftsman 1-1/2HP 315.17491 router severe vibration with t&g bit danmancalif Introductions 4 02-19-2014 11:41 PM
Sears Router bit description gary smyth General Routing 1 06-30-2011 10:23 PM
