Bosch Over the Table Hex Key - Router Forums
post #1 of 5 (permalink) Old 01-10-2017, 08:47 AM Thread Starter
inkslinger's Avatar
I have a Bosch 1617 EVS combo an I need a replacement for the hex key to make the fine adjustment on top of a router table. I didn't want to buy the mount for under the table just to get a key , Is there a replacement I can get or something else I can use?
inkslinger is offline
post #2 of 5 (permalink) Old 01-10-2017, 09:32 AM
Bosch 2610923193 T-Handle Hex Height Adjustment Wrench | Mathis Kelley
Stick486 is offline
post #3 of 5 (permalink) Old 01-10-2017, 11:07 AM Thread Starter
inkslinger's Avatar
Is the 2610923193 is the same as the 261092193?
Would you think it's a 1/8in or 3mm Hex Key
Was also looking for the RA1002 {Extension Control knob}
Both are for the RA1161
Any other Router parts for this that are inter changeable?
post #4 of 5 (permalink) Old 01-11-2017, 10:06 PM
I didn't like the stock hex key that came with my Bosch 16171 so I made a new one for table use.
I used a small chrome crank handle from an old Craftsman mini milling machine and epoxied an 1/8 inch hex key into the shaft area. The handle has a spinning knob on it for rapid height changes and the grooved edge helps mark the adjustments in increments.
If you make one just be sure the handle doesn't interfere with the router bit.
Tom
ThomL is offline
post #5 of 5 (permalink) Old 01-11-2017, 10:33 PM
My router has a 14mm nut that turns the threaded rod on my plunge so I use a socket and a speed wrench. Vintage PROTO USA No. 5280 3/8" SPEED WRENCH 17-1/4" | eBay You can get allen key sockets that fit it I'm just not sure if the ones on a socket would be long enough. The speed wrench is super fast.
Human Verification
Polk ultimate portable workbench roofner Tools and Woodworking 16 12-13-2016 10:15 PM
Add a jig saw table to your table saw pbriggs8 Project Plans and How To 11 06-14-2016 08:16 PM
Add router table with dust collector to your table saw pbriggs8 Project Plans and How To 16 06-02-2016 11:23 PM
Laguna TSS. MAFoElffen Tool Reviews 8 01-03-2016 06:10 PM
Integrating INCRA : Craftsman Table Saw [TS] & Router Part 3 [ii] Bridged X-cut Box SimonHartropp Jigs and Fixtures 1 10-27-2015 11:50 AM
