| This is a discussion on Moving Sub Base to Another Router within the Portable Routing forums, part of the Routers category; Hi Guys: Lots of info here and really got me thinking. I have a Porter ... |
| | #1 (permalink) | ||
| Registered User ![]() Join Date: Jan 2009 Location: Trenton, Ontario, Canada First Name: Don Posts: 26 ![]() |
Hi Guys: Lots of info here and really got me thinking. I have a Porter Cable Router and removed the Sub Base of it when I made a Router Table. It bolts to the Router with three screws. I also have a Ryobi 175 Router that the Base bolts on with two screws. The base is OK except I can't purchase brass bushings for it. (wrong size hole). My question is: Can I drill two holes in the Porter/Cable Base and screw it on to the Ryobi base. If so, How do I get everything lined up properly? I welcome any replies - Don. | ||
| | #2 (permalink) | |||
| Forum Contributor ![]() |
hi Don You can do that but it's tricky to get it right on the button because of the big hole, I would suggest you just get a adapter plate like the one below then just screw it down in place and then you can use the brass guides.. http://www.harborfreight.com/cpi/cta...emnumber=95160 ========= Quote:
__________________ MLCS Instruction Pages & Videos plus FREE MLCS Project Plans http://www.mlcswoodworking.com/shops.../instruct.html Part Finder find parts for your power tools http://www.ereplacementparts.com/ Need some help replacing the parts http://forums.ereplacementparts.com/ Many Router Tips from RWS http://www.routerworkshop.com/router_tip_glossary.html http://www.routerforums.com/email-ro...-members-only/ Router Tables ,Ready to use http://www.rt1000.com/ http://rt1000.com/_wsn/page2.html Bob J. | |||
| | #3 (permalink) | ||
| Registered User ![]() Join Date: May 2007 Location: I was born and raised in Holland Michigan First Name: Howard Posts: 1,516 ![]() |
Hello Don, I have a Ryobi and i think yours is like mine. Two screws hold The mount plate to the base. Mine came with collars that screwed unto the base, I fired up the metal lathe and turned a plate that attached to the holes, and the brass collars mount to it with the large brass nut, like P.C. You can get them from Ryobi i believe if you inquire. You can also re drill and attach the plate like BT3 suggested. I believe you'll have to drill.
__________________ John 3:16 Please fill out your profile, It helps us to know you better | ||
| | #4 (permalink) | ||
| Registered User ![]() |
I think ToolNow.com has the adapter you need cheap.
__________________ St. Louis, MO Retired Welding Inspector and past Ind Arts teacher | ||
| | #5 (permalink) | ||
| Registered User ![]() Join Date: Nov 2007 Location: Fayetteville, Georgia First Name: George Posts: 366 ![]() |
Milescraft might be a thought as well... "G" | ||
| | #6 (permalink) | ||
I don't know if the Woodworkers' Show come to your area, but a couple of years ago I picked up a couple of universal bases from their surplus dealer. I think they were Craftsman/MLS. At least so far they have fit every router I have tried them on. They use the plastic camlock bushings. + and -. You might get out your old drafting set and test you drafting skills on some plexiglass and make some.
| | #7 (permalink) | ||
Hi George II I 2nd. the Milescraft plate, it makes it so easy and quick.. http://www.amazon.com/Milescraft-120...381459&sr=1-10 http://www.amazon.com/Milescraft-121...ref=pd_cp_hi_2 ======
__________________ MLCS Instruction Pages & Videos plus FREE MLCS Project Plans http://www.mlcswoodworking.com/shops.../instruct.html Part Finder find parts for your power tools http://www.ereplacementparts.com/ Need some help replacing the parts http://forums.ereplacementparts.com/ Many Router Tips from RWS http://www.routerworkshop.com/router_tip_glossary.html http://www.routerforums.com/email-ro...-members-only/ Router Tables ,Ready to use http://www.rt1000.com/ http://rt1000.com/_wsn/page2.html Bob J. Last edited by bobj3; 01-24-2010 at 07:07 PM. | ||
| | #8 (permalink) | ||
If you could get it centered and the mounting holes line up it could be done. But I would advise against it. Buy and adapter or make one from a clear plastic. You could check Par Warner's web site and see if he sells one for the Ryobi. | ||
| | #9 (permalink) | ||
Ryobi bushings are larger than PC bushings. There are more than one Ryobi adaptor. I have one that will hold PC bushings and at least one that will hold Ryobi bushings. Toolsnow.com does not show the adaptors, but I know that is where I bought them. I think they were $2. I don't have the original package that oould have the model and part numbers. I think you would have to call them or go to one of their "Liquidator" stores to find them.
__________________ St. Louis, MO Retired Welding Inspector and past Ind Arts teacher Last edited by Clouseau; 01-27-2010 at 03:22 PM. | ||
| Old Glossary Terms | Mark | RouterForums.com News & Feedback | 0 | 10-14-2008 01:30 AM |
| Stanley 82902 Router Base | woodduck3 | Introductions | 7 | 08-20-2008 09:29 PM |
| Replacing Router Base | Weekendwoodworker | General Routing | 1 | 05-02-2008 04:55 PM |
| Bosch 1617 router base problem | bill kay | General Routing | 4 | 01-09-2008 11:53 AM |
| Model 320.17542 and table routing | trap | Table-mounted Routing | 41 | 07-03-2007 11:37 AM |
