| This is a discussion on Feed Direction, Complicated? within the Portable Routing forums, part of the Routers category; The easy way to remember the left from the right rule is to think of ... |
| | LinkBack (1) | Thread Tools | Display Modes |
| | #21 (permalink) | ||
| Forum Contributor ![]() |
The easy way to remember the left from the right rule is to think of the British MG sports car, M is on the left (motors) G is on the right (generators). When routing on the table, do NOT attempt to move the wood from left to right, it is likely to be thrown across the shop at high speed and push your fingers into the cutter, YOU HAVE BEEN WARNED..................
__________________ Harry The best advice that I can give a newcomer to routing is, learn to use the router mounted, this can be as simple as a board held in a vice, with the router firmly attached and a simple fence held with clamps, and when he/she feels competant and confident in it's use and is familiar with all aspects of safety, THEN, and only then proceed to learn how to use the router hand held. This is MY opinion, and may or may not coincide with that of the forum management, but is based on a lifetime of woodworking. http://members.dodo.com.au/~sharry02/ | ||
| | #22 (permalink) | |||
| Registered User ![]() Join Date: May 2006 Location: West Central Illinois "Forgotonia"; town of 20,000 80 miles from Peoria, Quad Cities, Springfield First Name: Tom Posts: 403 ![]() |
__________________ Tom Controversy is the engine that drives progress and growth of understanding; mistakes can be a stepping stone to expertise DO Something, DO ANYTHING to Stop Global Warming Last edited by mftha; 02-07-2009 at 10:53 PM. | |||
| | #23 (permalink) | ||
A very important point Tom that can't be over stressed.
| | #24 (permalink) | |||
| Registered User ![]() |
Maybe I can figure something out using John Deere or IH... ![]() | |||
| | #25 (permalink) | |||
| Registered User ![]() Join Date: Dec 2008 Location: Rio Rancho, New Mexico First Name: Ralph Posts: 734 ![]() |
__________________ - Ralph | |||
| | #26 (permalink) | |||
But to start a groove you have to run the stock thru the bit to create the first pass and In this case you trap the bit between the stock and the fence. Why this is okay? | |||
| | #27 (permalink) | ||
HI Guys I know I'm going to catch hell for this but the CLIMB cut works very well when you are milling/routing veneer plywood,,and some other woods, it packs the chips in the slot to keep the veneer from ripping BUT you should not go more than a 1/4" deep on each pass...to be use by the advance user only... ![]() A climb cut is just backwards from the way you should push the stock by the bit on the router table and it works very well with a plunge router also... but you must hold on to the stock at all times on the router table ![]() =======
__________________ MLCS Instruction Pages & Videos plus FREE MLCS Project Plans http://www.mlcswoodworking.com/shops.../instruct.html Part Finder find parts for your power tools http://www.ereplacementparts.com/ Need some help replacing the parts http://forums.ereplacementparts.com/ Many Router Tips from RWS http://www.routerworkshop.com/router_tip_glossary.html http://www.routerforums.com/email-ro...-members-only/ Router Tables ,Ready to use http://www.rt1000.com/ http://rt1000.com/_wsn/page2.html Bob J. | ||
| | #28 (permalink) | ||
Far from giving you hell Bj, I agree with you but it's only for the more advanced routologist and not for small pieces which can't be gripped securely. When routing around a corner from straight grain to cross grain, going backwards will prevent breakout, but I must stress again that the piece must be gripped firmly. To get back on my soap box, plunge routing especially using female templates does not present these safety problems and this is one reason why most of my routing is done this way and only minor operations on the table.
| | #29 (permalink) | ||
Finally the "backwards around the corner" was mentioned. Because I use a router only occassionaly, I usually forget this and have tear out. | ||
| | #30 (permalink) | |||
| Registered User ![]() Join Date: Dec 2008 Location: North East Pennsylvania First Name: Gerard (AKA: Gerry ) Posts: 247 ![]() |
Let you guys know about it and attempt that new-fangled embed a video thingie. Enjoy and learn! Cordially, Gerry | |||
LinkBacks (?)
LinkBack to this Thread: http://www.routerforums.com/portable-routing/12131-feed-direction-complicated.html | ||||
| Posted By | For | Type | Date | |
| where to get PC 890 instructional CD - Woodworking Talk - Woodworkers Forum | This thread | Refback | 02-19-2010 12:10 AM | |
| Simple direction of feed and scoring… | BobandRick | General RouterWorkshop.net Discussion | 0 | 12-27-2008 02:31 PM |
| Direction of feed for router | EUCLIDES AGOSTO | General Routing | 6 | 10-27-2006 04:15 PM |
| Feed direction | tscott | General Routing | 8 | 07-04-2006 07:06 PM |
| New - Boxjoint Cutting feed direction | Makavelli | Table-mounted Routing | 8 | 07-04-2006 03:49 PM |
