| | #1 |
| Registered User New Member | Just took my Hitachi M12V out of the box after about 6 years. Started working with an ogee bit to edge some frames. The machine quit/died after about 2 minutes of operation. Tapping it on the bottom revived it only momentarily. Needless to say a 10 minute job lasted an hour. Please if anyone can help with what the problem might be, I would appreciate it greatly. Best regards, Roy |
| | #2 | |
| The Router Guys Forum King | Quote:
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. | |
| | #3 |
| Router King Supreme Forum King | It sounds like the brushes are causing the problem. Sitting for that lenght of time could cause corrosions on the armature. |
| | #4 |
| The Router Guys Forum King | Good point, should check the brushes first.
| | #5 |
| Registered User New Member | Thanks for the info. Will check the brushes tomorrow. Might be something growing in there. Roy |
| | #6 |
| Registered User Forum Geek | Any update on the M12V and brushes? |
| | #7 |
| Registered User Dedicated Member | Probably the first thing to fail, assuming normal use is the POWER CORD. I have seen many failures in POWER CORDS where the STRAIN RELIEF is located. The wires inside the strain relief are broken due to the stresses applied to them by constant movement focused on the relief it's self. I am not sure this is very clear - but, lets assume that the appliance is intermittant, it's reasonable to assume the simpliest first - is it the power cord? Before replacing the Brushes, with very fine emory, be sure to clean the (is it the commutator?, I forget) surfaces where the brushes contact. Hope this helps. cfm |
| 1/4" Collet for Hitachi M12V | RzzB | General Routing | 37 | 05-27-2008 09:11 AM |
| New Hitachi Routers not as good as the old ones??? | ACV | General Routing | 9 | 05-10-2008 10:59 PM |
| DC for a Hitachi router | jnam | Portable Routing | 2 | 09-12-2006 02:12 PM |
| Hitachi M12V issue | Warren White | General Routing | 4 | 03-23-2005 11:03 PM |
| hitachi m12v and spiral upcut bit | routerman1969 | General Routing | 1 | 02-19-2005 06:08 AM |
