Help
Go Back   Router Forums > Routers > Portable Routing
Ryobi ERT-1150V router
This is a discussion on Ryobi ERT-1150V router within the Portable Routing forums, part of the Routers category; Hi everyone I have just obtained a unused but incomplete Ryobi 1150v router, the collet ...
Old 05-13-2009, 01:23 PM   #1 (permalink)
First Name: trevor
trevor is on a distinguished road
Default Ryobi ERT-1150V router
Report Post Report This Post!
Hi everyone
I have just obtained a unused but incomplete Ryobi 1150v router, the collet nut was missing so I obtained a new collet nut through Ryobi, however although the collet nut fits the router the collets are narrower than the collet barrel by quite a lot and even with the collett nut done up the colletts fall out, finally can anyone tell me if there should be a sleeve inserted as well as the collet in the collet barrel to prevent this occuring, or have I got the wrong collets.
Trevor
trevor is offline
Old 05-14-2009, 02:50 PM   #2 (permalink)
dutchman 46's Avatar
First Name: Howard
dutchman 46 is on a distinguished road
Hello Trevor: I can only guess. However i do have Ryobi routers. With my routers, there is only a nut, and a barrel type sleeve that is slit in 4 places. My first thought is that you could have a 1/4 in. collar, and a nut for a 1/2 in shaft. I would call Ryobi and tell them what the problem is, and they may be able to send the correct collar. Someone will be able to reply here and may know more than me.
John 3:16
dutchman 46 is offline
Old 05-17-2009, 03:10 PM   #3 (permalink)
First Name: trevor
Hi John
Thanks for that, I am going to order a set of collets from ryobi, and hopefully that will do the job.
Trevor
trevor is offline
Old 06-05-2009, 11:29 AM   #4 (permalink)
First Name: Howard
Hope that we are talking the same thing. The collet would only be the thin sleeve that fits into the not to tighten the bit in place. They are bough as a collet and nut. However, you must have the complete model and information in order to order it. When you talk about a set, it sounds as it is the rub collars that follow a template. If that is falling through the hole, you may need an adapter to hold it. I know that i am not that clear, So i wish you well.
John 3:16
Old 06-15-2009, 12:50 PM   #5 (permalink)
First Name: trevor
Hi John,
Finally got in touch with ryobi technical, the original collet nut supplyed did not have a retaining ring in it, however they did supply another one with retaining ring and it works just fine now.
Again thank you for your help.
Trevor
trevor is offline
New Router my way reible General Routing 16 03-13-2010 05:25 PM
Freud FT3000VCE 3-1/4 HP Variable Speed Plunge Router Bridge Introductions 6 07-23-2008 03:17 PM
Opinion NEEDED ASAP! Please Ryobi table & Router on sale this weekend Evil Scotsman Table-mounted Routing 5 07-06-2008 08:34 AM
Newbie with an unusual router application wm_brant Introductions 6 10-31-2007 03:16 PM
Ryobi 501W router Table cameyers Table-mounted Routing 0 10-03-2005 08:02 AM
