| | #11 |
| Registered User Jr. Member | With that big of a bit or guide I would rather use a fence or set up a pin router on my table. What in the world are you cutting? |
| | #12 | |
| Registered User Forum King | Quote:
Tom | |
| | #13 | |
Sounds like a good idea Tom | |
| | #14 | |
http://www.routerforums.com/table-mounted-routing/113-any-one-using-pin-simular-pin-router-attachment.html and tell us about it????? OK now we can get back to the subject at hand. Ed | |
| | #15 |
| Registered User | A few days ago there was a table on using guide bushings with router bits and what distance you need from the pattern. I tried to copy it and couldn't. I do not know why and now I can not find it again on router form. Will someone tell me where it is? Thank you Walter |
| | #16 | |
Try here: www.routerforums.com/showthread.php?t=163 Ed | |
| | #17 |
| Registered User Forum King | I have never found a good reason for having a table to do the calculations I simply find out what I need and insert the required guide and cutter. I work it out at the source. I suppose a table would be of interest to those starting out with template guides. Learn how to use the guides and you will increase your router's potential by 50% Tom |
| | #18 | |
Sorry I did answer this posting before now please forgive me. I was preparing some legs for a number of chairs and the reason why I used a 40mm Guide was I was routing with a 33mm cutter that required the necessary clearance. The cutter could not be used with any smaller guide that I had at the time (and still do not have) see pics of legs | |
| | #19 |
| Registered User Forum Fanatic | I often use the router bush that came with the router which is 30mm. I also use a 16mm (5/8") and a 11mm (7/16") that came with my dovetail jig. I usually use the bushes when routing to jigs I have made from MDF.
__________________ Dewy support team at Paltalk voice chat program |
| | #20 |
| Registered User Forum King | Dewy What type of project would you use the guides for? Have you used the 40mm Guide? Tom |
| Template Guide sizes | mftha | Guide Bushings and Templates | 11 | 06-04-2008 06:35 PM |
| 40mm Guides for Templates + more | bobj3 | Jigs and Fixtures | 30 | 07-23-2007 12:09 AM |
| Hitachi M12V template guides? | vwmowery | General Routing | 6 | 09-01-2006 12:51 AM |
| Porter-Cable template guide no where to be found | jnam | Portable Routing | 5 | 07-21-2006 08:54 PM |
| Template Guide depth | ttait | General Routing | 3 | 10-03-2004 06:16 PM |
