Go Back   Router Forums > Routers > Portable Routing
Portable Routing Discussion area on the Portable Router and its applications. Bob and Rick say, "If the piece is bigger than the router then chances are it should be routed with the portable router."
Thread Tools Display Modes
Old 09-21-2004, 07:39 AM   #1
template tom
Forum King
Default The use of template guides (Guide bushes)
As a matter of interest
I have asked this question on many forums on woodworking and since this seems? to be a dedicated? router forum I thought I would also ask here. How many people using a router would use the template guides (guide bushes) on a regular basis to complete projects or part of their projects. How many users would consider using a large guide say 1 31/64ths (40mm) or even a 2'' guide.
Old 09-21-2004, 08:06 AM   #2
ejant
Router King
Supreme Forum King
ejant's Avatar
ejant will become famous soon enough
If the project is going to be made multiple times and a template is needed then the use of bushings may be necessary
As fas a large bushing go you'll need a baseplate to accomodate them.
ejant is offline   Top - Reply with Quote
Old 09-21-2004, 10:59 AM   #3
reible
Supreme Forum King
reible's Avatar
I use guides often, the largest I have is a 1 1/4 OD about the limit for the standard PC guides. I think oak park has a larger dia. set (1 1/2").
Now tell us why we might want a 40mm or 2" guide........
Ed
Old 09-21-2004, 06:36 PM   #4
kp91
Forum King
kp91's Avatar
First Name: Doug
I use bushings pretty regularly, ever since I had one project severely damaged when using a top guided pattern bit. The lock collar on the bearing came loose, and the bearing worked its way up the shank and above the template. Guides just seem a little more "foolproof."
They also remove any excuses for taking too big of cuts. Just chuck up a larger OD guide, and you can use the same template, but nibble off the waste.
I do have a favorite 1/2 in flush trim bit that I use a lot as well, just because it cuts so well.
1 John 1:9
Old 09-22-2004, 05:55 AM   #5
template tom
Forum King
Ed
Thanks to all who replied
In answer to your question Ed
(1) A greater range of cutters can be used
(2) You have a good chance at seeing the cutter in action
(3) All that waste material will clear more readily without the cutter over heating
(4) ......and the most important reason, Small cutters such as the 1/4" range when in use, the chuck will penetrate through the guide to give the depth required without 'Crimping' that extra bit out of the chuck therefore adding safety awareness to your routing.
There are other reasons for the use of the 40mm but these are the main reasons.
Once the templates are constructed people with impaired vision and even totally blind people can use the method
With the use of the guides I have produced projects that was omce considered only possible with a CNC router
Tom
Old 09-22-2004, 05:57 AM   #6
template tom
Forum King
Ed
Tried to send a posting with answer unable to send This is only a trial before I submit my answer or you could email me
Tom
Old 09-23-2004, 08:38 PM   #7
reible
Supreme Forum King
reible's Avatar
Default Just an Idea how to get your large guide bushing
I was thinking about this subject when an idea came to me. I have not done this and maybe it will not work but then again it might.
Make a new sub-base then when you make the holes make them the size of the a piece of 2" or what ever PVC pipe. You might want to use 3/8" thick materal then have the pipe inset 1/4". make the PVC just short of a 1/2" then glue it in place.
If you make this let us know how it worked, I might want to make one too. Of course detail of what you did would help.
Ed
Old 09-23-2004, 09:58 PM   #8
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
This is great stuff!!! But, shouldn't this be in router forums/portable routing, maybe?
Rick and Bob
The Router Guys
Old 09-24-2004, 01:42 AM   #9
reible
Supreme Forum King
reible's Avatar
Anyone know how to move threads?
any one any one at all?
I sent mail to Mark so we will see what happens.
Ed
Old 09-24-2004, 01:47 AM   #10
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
I will get Mark to move the thread...maybe we should add templates and router bits to portable routing forum.
Rick and Bob
The Router Guys
Template Guide sizes mftha Guide Bushings and Templates 11 06-04-2008 06:35 PM
40mm Guides for Templates + more bobj3 Jigs and Fixtures 30 07-23-2007 12:09 AM
Hitachi M12V template guides? vwmowery General Routing 6 09-01-2006 12:51 AM
Porter-Cable template guide no where to be found jnam Portable Routing 5 07-21-2006 08:54 PM
Template Guide depth ttait General Routing 3 10-03-2004 06:16 PM
