| | #1 |
| Registered User Forum King | As a matter of interest I have asked this question on many forums on woodworking and since this seems? to be a dedicated? router forum I thought I would also ask here. How many people using a router would use the template guides (guide bushes) on a regular basis to complete projects or part of their projects. How many users would consider using a large guide say 1 31/64ths (40mm) or even a 2'' guide. |
| | #2 |
| Router King Supreme Forum King | If the project is going to be made multiple times and a template is needed then the use of bushings may be necessary As fas a large bushing go you'll need a baseplate to accomodate them. |
| | #3 | |
Now tell us why we might want a 40mm or 2" guide........ Ed Last edited by reible; 09-21-2004 at 10:27 PM. | |
| | #4 |
| Marine Engineer Forum King | I use bushings pretty regularly, ever since I had one project severely damaged when using a top guided pattern bit. The lock collar on the bearing came loose, and the bearing worked its way up the shank and above the template. Guides just seem a little more "foolproof." They also remove any excuses for taking too big of cuts. Just chuck up a larger OD guide, and you can use the same template, but nibble off the waste. I do have a favorite 1/2 in flush trim bit that I use a lot as well, just because it cuts so well.
| | #5 | |
| Registered User Forum King | Quote:
In answer to your question Ed (1) A greater range of cutters can be used (2) You have a good chance at seeing the cutter in action (3) All that waste material will clear more readily without the cutter over heating (4) ......and the most important reason, Small cutters such as the 1/4" range when in use, the chuck will penetrate through the guide to give the depth required without 'Crimping' that extra bit out of the chuck therefore adding safety awareness to your routing. There are other reasons for the use of the 40mm but these are the main reasons. Once the templates are constructed people with impaired vision and even totally blind people can use the method With the use of the guides I have produced projects that was omce considered only possible with a CNC router Tom | |
| | #6 | |
Tried to send a posting with answer unable to send This is only a trial before I submit my answer or you could email me Tom | |
| | #7 | |
Make a new sub-base then when you make the holes make them the size of the a piece of 2" or what ever PVC pipe. You might want to use 3/8" thick materal then have the pipe inset 1/4". make the PVC just short of a 1/2" then glue it in place. If you make this let us know how it worked, I might want to make one too. Of course detail of what you did would help. Ed | |
| | #8 |
| The Router Guys Forum King | This is great stuff!!! But, shouldn't this be in router forums/portable routing, maybe?
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. |
| | #9 | |
any one any one at all? I sent mail to Mark so we will see what happens. Ed Last edited by reible; 09-24-2004 at 01:46 AM. | |
| | #10 |
| The Router Guys Forum King | I will get Mark to move the thread...maybe we should add templates and router bits to portable routing forum.
| Template Guide sizes | mftha | Guide Bushings and Templates | 11 | 06-04-2008 06:35 PM |
| 40mm Guides for Templates + more | bobj3 | Jigs and Fixtures | 30 | 07-23-2007 12:09 AM |
| Hitachi M12V template guides? | vwmowery | General Routing | 6 | 09-01-2006 12:51 AM |
| Porter-Cable template guide no where to be found | jnam | Portable Routing | 5 | 07-21-2006 08:54 PM |
| Template Guide depth | ttait | General Routing | 3 | 10-03-2004 06:16 PM |
