Go Back   Router Forums > Routers > Portable Routing
Rate This Thread - Anyone have an interesting table they use for portable routers?.
Thread Tools Display Modes
Old 09-23-2004, 05:13 PM   #1
reible
Supreme Forum King
reible's Avatar
Default Anyone have an interesting table they use for portable routers?
I know the guys on the workshop use their router table for a lot of the hand held jobs they do but is anyone using some thing else? This could be job site or in the backyard.......
I have a "Workmate" that comes in handy for this.
Ed
Old 09-23-2004, 05:26 PM   #2
delroy33
Supreme Forum King
delroy33's Avatar
delroy33 will become famous soon enough
i have a pc #698 table. it has a 16 3/4" by 19 3/4" csat aluminum to with 12 7/8" sides. i have mine on a 24 1/2" high stand giveing me a top to floor dim. of 37 5/8".
roy
start square, finish square
delroy33 is offline   Top - Reply with Quote
Old 09-23-2004, 09:14 PM   #3
Julie
Forum Geek
Julie's Avatar
Julie is on a distinguished road
Well I was going to use a Workmate, but my router doesn't fit through the space in the middle. I was surprised because I've seen the Workmate shown as a router table in a few magazines. Maybe my router is just FAT (it's a Hitachi 12V)??
So, for now it's just sitting on my homemade workhorses, waiting for me to make a nifty table for it. I do have the Oak Park table top. I would have liked to get the table, too, but all the stuff is so darn expensive. (Hi Bob and Rick! )
~Julie~
Julie is offline   Top - Reply with Quote
Old 09-23-2004, 10:39 PM   #4
reible
Supreme Forum King
reible's Avatar
Default let me change the question
Hi,
Not the answers I was expecting....... Interesting too so feel free to post more then add some more like what I'm asking about after you read my second try below.
So let me try this again
I was think of a "work table" or "saw horses" or "xxxx" that you might use when you are not using your router in a table manor. Like on Router Workshop they use the table and mount fixtures to it then hand hold the router to do the work.
I use my workmate as a work surface then clamp the work and fixtures to it. I have a Ryobi "quick stand" a nice taller stand at 33 1/2" and an aluminum step platform that is nice low surface.
Now what do you have that is like this or homemade or available only in Canada??????
Ed
Old 09-24-2004, 08:48 AM   #5
Nasanut
Jr. Member
Nasanut's Avatar
Nasanut is on a distinguished road
My table is homemade from some discarded kitchen countertop. The router plate is a 9 inch round Veritas which has only a 1 n 3/16 hole but comes with template and tools to install it into any table top. Would like to have the RW or better plate with multiple inserts but I'm a cheapskate.
Nasanut is offline   Top - Reply with Quote
Old 09-24-2004, 11:16 AM   #6
DONALD
Sr. Member
DONALD is on a distinguished road
I have a makeshift work table that I use mostly with my CMS but its handy anytime I need a large flat surface to work on. I attached a 2x6 to a piece of 3/4 inch plywood about 4'x6'. I open the jaws of my workmate....put the 2x6 in and close the jaws. I take it apart when I'm thru using it and prop it against the wall. Works for me.
DONALD is offline   Top - Reply with Quote
Old 09-24-2004, 01:57 PM   #7
reible
Supreme Forum King
reible's Avatar
Is the 2" side or the 6" against the plywood? This sounds like something I should make for myself.
Ed
Old 09-25-2004, 09:43 PM   #8
DONALD
Sr. Member
The 2x6 is lying flat against the plywood. I guess it could go either way....I just felt it would be stronger the way I made it. I also use it with my CMS......I just use c clamps to hold the saw on the plywood. I made it out of new plywood and it aslso made a good surface for drawing or writing down measurements. Try it you'll like it.
Old 09-25-2004, 10:40 PM   #9
reible
Supreme Forum King
reible's Avatar
I think I will, it sounds like it will be easy to store as well, very good!
Ed
Old 09-26-2004, 08:03 AM   #10
ejant
Router King
Supreme Forum King
ejant's Avatar
ejant will become famous soon enough
I've clamped a large sheet of plywood to the table and have used it as an assembly table if this is what you mean.
ejant is offline   Top - Reply with Quote
Router Table Help Which One! bigroccrek Table-mounted Routing 25 04-08-2008 10:57 PM
Triangular Shaped Router Table w/ 3 Routers awh Table-mounted Routing 19 08-31-2007 08:27 PM
New Router Table RustyW Show N' Tell 10 08-28-2006 01:23 AM
Table mount routers... Bluegillman General Routing 1 12-02-2004 09:37 AM
