| This is a discussion on Adjusting groove & dado widths. within the Portable Routing forums, part of the Routers category; Hi. I'm horrified at the idea of using a carrier sled through your planer without ... |
| | #11 (permalink) | ||
| Registered User ![]() Join Date: Jun 2009 Location: Valley Forge, Pennsylvania, USA First Name: Eoin Posts: 5 ![]() |
Hi. I'm horrified at the idea of using a carrier sled through your planer without at the very least ensuring that the pieces are firmly adhered to the sled with double sided carpet tape and then wedged at the sides and end. That is a very dead planer just waiting to happen. If your pieces are shorter than the distance between the in- and out-rollers, you WILL sooner or later have an accident, carrier sled or not. 14 inches is the minimum we will ever put a piece through a planer in our (professional) shop. I really don't think you can be precise enough ajusting your slot with a router. A few thou too much and you've ruined it. Bob's sander block method is probably the best. Use a long block (8 to 10 inches long). By that method, you can aim for an arrow shaped slot (where it's slightly wider at the starting end by a thou or three) so that the shelf will slide in all the way when glued. Not so much that it rattles, though. You definitely shouldn't need to hammer it dry - with glue, you'll never get it in. Slow set glue helps here. There is a proper tool for this job - it's called a side rabbet (or rebate) plane, such as the Stanley 98/99 if you can find one or the Lie-Nielsen version of the same, currently available. Set it to take a micro-fine pass. Eoin | ||
| | #12 (permalink) | |||
| Registered User ![]() |
rstermer | |||
| | #13 (permalink) | ||
It's worth while to make a dado jig. I build the woodsmith one linked to in an early post and it works great. I use my stock to adjust the width of the dado and that's it. After using it a few times you will learn that you have to fine tune one area or another, but once your past that you don't have to think too much. I just built a book shelf with it and nothing but smiles when it came to the fit. | ||
| | #14 (permalink) | ||
| Registered User ![]() Join Date: Sep 2008 Location: Istria, Croatia First Name: Peter Posts: 932 ![]() |
Do you need one of these? Dakota Micro Dado Maker - Metric (DK1016) - Buy online from Rutlands.co.uk This is from a UK supplier but I've seen them in US catalogues too. Cheers Peter | ||
| | #15 (permalink) | ||
Infinity Tools claims an exclusive ! Obviously not! I've seen them on the China dealers' sites. Precision Router Dado Jig-Carbide Router Bits | Router Bit Sets | Shaper Cutters | Saw Blades | Planer Knives | Jointer Knives | Infinity Cutting Tools I got mine from Rutlands when they were on special offer. Nicely made and came in a wooden box. Cheers Peter | ||
| | #16 (permalink) | |||
| Forum Contributor ![]() |
Hi Peter Very nice jig or make your own ![]() see below ===== Quote:
__________________ MLCS Instruction Pages & Videos plus FREE MLCS Project Plans http://www.mlcswoodworking.com/shops.../instruct.html Part Finder find parts for your power tools http://www.ereplacementparts.com/ Need some help replacing the parts http://forums.ereplacementparts.com/ Many Router Tips from RWS http://www.routerworkshop.com/router_tip_glossary.html http://www.routerforums.com/email-ro...-members-only/ Router Tables ,Ready to use http://www.rt1000.com/ http://rt1000.com/_wsn/page2.html Bob J. | |||
| | #17 (permalink) | |||
The scales were an odd width, 11/16 or something like that.
__________________ John Schaben ![]() "I haven't failed, I have simply discovered several hundred ways that don't work" | |||
| | #18 (permalink) | ||
| | #19 (permalink) | ||
Hi Peter Thanks, the holes are in place to let the chips out,it slides down the clamp bar and to adjust it,just unclamp it and move it over very quick and easy. it can be used for 1/4" slots to ~ , I use a business card the norm for that fine tweaking adjustment..lets; take 3/4" MDF stock, make the 1st slot and move it over by a business card,,then reclamp it, make one more pass ,then it just pops in without any sanding.. ![]() ========
| | #20 (permalink) | |||
ive seen those clamps with the accessories advertised. do you remember where you got yours. at some time ive got to get a straight edge clamp guide. i thought maybe a 50 inch one. ? p.s. i see holes to mount the router, but couldnt you use it with an 1 1/2 guide alone?
__________________ light travels faster than sound, this is why some people seem bright til you hear them speak. Please Please Please edit your profile with a name and location so we can better assist you and make for a friendlier forum levon Last edited by levon; 08-08-2009 at 09:02 AM. | |||
| Dado cuts in plywood | BK9MJE | Tools and Woodworking | 4 | 04-18-2009 01:28 PM |
| Wedge tonuge and groove (CMT 855.510.11) | Drew Eckhardt | Router Bits - Types and Usage | 2 | 01-23-2009 09:39 PM |
| Cutting a curved groove | rsmtg | Introductions | 3 | 09-25-2008 10:56 PM |
| Tongue and groove bits | archer_456 | General Routing | 4 | 02-18-2005 05:51 AM |
