Help
Go Back   Router Forums > Routers > Portable Routing
Hot melt glue to hold small parts for pattern routing?
This is a discussion on Hot melt glue to hold small parts for pattern routing? within the Portable Routing forums, part of the Routers category; I use hot melt when template routing using polycarbonate templates. Double sided tape for everything ...
Old 06-15-2009, 12:19 PM   #11 (permalink)
Mike Wingate's Avatar
First Name: mike
Mike Wingate is on a distinguished road
Report Post Report This Post!
I use hot melt when template routing using polycarbonate templates. Double sided tape for everything else.
Mike Wingate is offline
Old 06-15-2009, 09:53 PM   #12 (permalink)
harrysin's Avatar
harrysin is just really niceharrysin is just really nice
Wouldn't it be a dull world if we all did things the same way! The important thing is that we feel comfortable in all the things we do in life.
Harry
The best advice that I can give a newcomer to routing is, learn to use the router mounted, this can be as simple as a board held in a vice, with the router firmly attached and a simple fence held with clamps, and when he/she feels competant and confident in it's use and is familiar with all aspects of safety, THEN, and only then proceed to learn how to use the router hand held. This is MY opinion, and may or may not coincide with that of the forum management, but is based on a lifetime of woodworking.
http://members.dodo.com.au/~sharry02/
harrysin is offline
Old 06-16-2009, 06:30 AM   #13 (permalink)
rstermer is on a distinguished road
Originally Posted by harrysin View Post
I've tried and don't like hot melt glue for this purpose, I use small panel pins, they cost next to nothing and are available in many lengths, these are the most common sizes that I use, the smallest is 5/8" and the longest is 1.5".
You would think, maybe not...I would think that with the recent popularity of pin nailers, the pins for them would be readily available. Not so, I tried Lowes and Sears yesterday, no luck. I'll try Home Depot this morning. If I don't have any luck,I'll use brads from my brad nailer and clip off the heads. This part will not be receiving a high level of finish, so a small hole won't be a problem. I was surprised the pins were not generally available.
Regards,
rstermer
rstermer is offline
Old 06-16-2009, 08:11 AM   #14 (permalink)
derek willis's Avatar
First Name: Derek
derek willis will become famous soon enough
Harry,
That's a world wide quote, I agreee, we all do it our own way, in fact I've been using hot melt today for exactly that same reason.
Derek
derek willis is offline
Old 06-16-2009, 09:21 AM   #15 (permalink)
First Name: Vicki
BlondeWood is on a distinguished road
Default pin nails
Regards,
rstermer
I found pin nails at Harbor Frieght. Also, at my Lowes when I couldn't find nails I asked and they were in a back area called "contractors section" and sometimes I find stuff like that in the Arrow staple section.
Vicki
BlondeWood is offline
Old 06-16-2009, 09:46 AM   #16 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
Hi Guys
I love the pin nailer,,,I don't know how anyone could be without one in the wood shop,,I started doing alot on template work as of late but they work so well for many other jobs as well
I'm always amazed how the little pin nailer can put in a 1" long pin in hardwood molding and not spit the stock..like so many of the brad nailers can do easy..
I still use tape when the nailer will not do the job and I have also use hot glue that stuff sucks,,,it "leaves" a spot on the wood and seals the wood so the stain/finish can't go on.
Not to say anything waiting for the glue to get hot...
Once you have pin nailer it will be the one you pickup to use alll the time and the nails are cheap unlike the tape.. or glue sticks...
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
Many Router Tips from RWS
http://www.routerworkshop.com/router_tip_glossary.html
http://www.routerforums.com/email-ro...-members-only/
Router Tables ,Ready to use
http://www.rt1000.com/
http://rt1000.com/_wsn/page2.html
Bob J.
Old 06-16-2009, 09:58 AM   #17 (permalink)
harrysin's Avatar
"so a small hole won't be a problem."
There shouldn't be any pin holes if the template is on top and a bottom bearing cutter is used.
Harry
harrysin is offline
Old 06-20-2009, 02:05 PM   #18 (permalink)
First Name: gary
garycurtis is on a distinguished road
I use hot glue gun all the time with my router. To glue down little fence and patterns for hand routing. The good thing is, you can just pry the stuff up and discard when done.
An English guy gave a router class and showed this method. Works fast and is easy. It helps to have a relatively slick and clean work surface. My wife just retired from the movie studios as costume designer. On Oscar night, how do you think they make emergency fittings to those $8000 dresses? Cut, snip, glue gun.
Gary Curtis
Northern California
garycurtis is offline
Old 06-20-2009, 06:53 PM   #19 (permalink)
Harry- Maybe I'm not understanding how it is done. Here is my thought as to how I would set up to make the cut. I would first stick some pins (3 or 4) into the bottom side of my pattern, since it is made of red oak and is very hard. Then I'd press my pattern down onto a board made of a softer wood, such as pine, which would be clamped to the bench. Next, I'd stick some more pins into the top side of my pattern and would then press the blank to be profile routed onto those pins. At that point I'd have a sandwich consisting of my soft base board, on top of that would be the pattern and on top of that would be the blank for the piece to be duplicated, all of it held together by the pins. I'd probably also set up some support pieces around the sandwich so the router wouldn't tip. Then I'd route away using a cutter with a bottom bearing.
Alternatively, I could put the piece to be routed in the middle, put the pattern on the top and use a cutter with a top bearing to make the cut (which as I think of it would probably be my preference as I would be able to see the pattern as I worked).
Have I got it right, or am I missing something important? Thanks for your thoughts.
rstermer
rstermer is offline
Old 06-20-2009, 10:45 PM   #20 (permalink)
harrysin's Avatar
May I offer my sincere apologies and ask you to ignore that post of mine. Had I not posted it late at night, I would have pleaded that I was DAY dreaming. Possibly what I was meaning was that if the Oak template is on the top of the new material and pinned from below, then there would be no pin holes in the face of the template.
In spite of all this I personally use pins believing that there is no chance of movement between the pieces, bearing in mind that here in Western Australia the temperatures reach into the 40+*C
Harry
harrysin is offline
Routing small projects dennis.degelmann Introductions 6 02-28-2009 07:56 PM
Small parts holding jig g-man Jigs and Fixtures 6 10-18-2006 06:28 PM
routing small pieces zxxer12 General Routing 9 03-21-2005 03:40 PM
