| This is a discussion on Hot melt glue to hold small parts for pattern routing? within the Portable Routing forums, part of the Routers category; I need to duplicate a small oak part (size approx. 7" x 2" x 0.5"). ... |
| | #1 (permalink) | ||
| Registered User ![]() |
I need to duplicate a small oak part (size approx. 7" x 2" x 0.5"). I will only need to make 1 copy. Will this work ok? Glue the original part (the one being duplicated) to a 2' long board with a couple of spots of hot melt glue. Glue the blank for the part to be duplicated to the the original part with 2 more drops of hot melt glue. Clamp the board to the bench, then pattern route. Are their other/better ways to do it? Thanks, rstermer edited to add part thickness Last edited by rstermer; 06-14-2009 at 06:45 PM. | ||
| | #2 (permalink) | ||
im sure someone can give you a better answer than me, but i would try double stick tape or if its thin enough, pin nails. i use a lot of pin nails and really like them. im not sure if the 2' is wide or thick?
__________________ light travels faster than sound, this is why some people seem bright til you hear them speak. Please Please Please edit your profile with a name and location so we can better assist you and make for a friendlier forum levon | ||
| | #3 (permalink) | |||
rstermer | |||
| | #4 (permalink) | ||
the tape i use isnt carpet tape and you can cut it to any size, but not knowing just how your piece looks it may not work. the manco tape is very sticky. the hot melt glue will probably work, i just havent had that great of success with it. can you predrill and put in 2 screw or do you think it would split? then the holes may present a problem. like i said, someone more experienced will be able to help you more. i just was trying to help if i could. btw, i bought a pin nailer from amazon for about 30 bucks and love it.
| | #5 (permalink) | |||
RAS | |||
| | #6 (permalink) | ||
its not a big brand name but it works, and its looks like it was 39 dollars. Amazon.com: Grip 23 Gauge Pin Air Nailer Gun: Home Improvement
| | #7 (permalink) | ||
| Forum Contributor ![]() |
Hi Guys I agree with levon,pin nails work very well,but if you don't have one right now find some very small nails you have in the hardware box,,,2 or 3 will do the job,they only need to go in about 1/4" deep in the stock, a pair of needle vise grips work well to hold them to put in place.. sure saves the black and blue finger nails if you miss... ========
__________________ MLCS Instruction Pages & Videos plus FREE MLCS Project Plans http://www.mlcswoodworking.com/shops.../instruct.html Part Finder find parts for your power tools http://www.ereplacementparts.com/ Need some help replacing the parts http://forums.ereplacementparts.com/ Many Router Tips from RWS http://www.routerworkshop.com/router_tip_glossary.html http://www.routerforums.com/email-ro...-members-only/ Router Tables ,Ready to use http://www.rt1000.com/ http://rt1000.com/_wsn/page2.html Bob J. | ||
| | #8 (permalink) | ||
I've tried and don't like hot melt glue for this purpose, I use small panel pins, they cost next to nothing and are available in many lengths, these are the most common sizes that I use, the smallest is 5/8" and the longest is 1.5".
__________________ Harry The best advice that I can give a newcomer to routing is, learn to use the router mounted, this can be as simple as a board held in a vice, with the router firmly attached and a simple fence held with clamps, and when he/she feels competant and confident in it's use and is familiar with all aspects of safety, THEN, and only then proceed to learn how to use the router hand held. This is MY opinion, and may or may not coincide with that of the forum management, but is based on a lifetime of woodworking. http://members.dodo.com.au/~sharry02/ | ||
| | #9 (permalink) | ||
Harry, Bob & Levon- Thanks for your replies. Pins seem to be universally preferred, so that is how I will go. rstermer | ||
| | #10 (permalink) | ||
| Registered User ![]() Join Date: Jan 2009 Location: Oxfordshire England First Name: Derek Posts: 483 ![]() |
I always use hot melt glue when pattern routing on the table, a few spots is enough and will hold under all circumstances, can be a bit difficult to separate, but with a flat knife blade it will come apart, any glue left behind can be removed cleanly with Methylated Spirit, this method I have used in preference to tape for about 15 years.
__________________ A friend is a good egg even if they are slightly cracked! Derek | ||
| Routing small projects | dennis.degelmann | Introductions | 6 | 02-28-2009 07:56 PM |
| Small parts holding jig | g-man | Jigs and Fixtures | 6 | 10-18-2006 06:28 PM |
| routing small pieces | zxxer12 | General Routing | 9 | 03-21-2005 03:40 PM |
