how to cut a square hole with portable router? - Router Forums
post #1 of 13 (permalink) Old 11-27-2009, 03:48 AM Thread Starter
First Name: Neil
Default how to cut a square hole with portable router?
Hi,
I hope this isnt a completely basic question - im still new to the world of routing
I have a piece of 18mm plywood, about 500mm by 500mm. I also have another piece of plywood, also 18mm which is about 250mm by 250mm.
I need to cut a 250mm by 250mm square hole in the bigger piece of wood so the smaller bit fits in it nice and flush.
whats the best way of going about this? I was going to put them on top of each other and screw a frame round the smaller piece to use as a template for the flush trim bit but its too thick. So how do I do it?
Cheers!
Neil
kingnerk is offline
post #2 of 13 (permalink) Old 11-27-2009, 03:53 AM Thread Starter
First Name: Neil
if anyone is interested this is what im building
Free Speaker Plans - Free Speaker Plans • View topic - HD15 BUILD PICS
kingnerk is offline
post #3 of 13 (permalink) Old 11-27-2009, 04:58 AM
gav
Country: Croatia
First Name: Gavin
I would rough cut it out with a jigsaw, then I would trim the edges to the line by running the routers base plate along a straight edge that's clamped to the ply. You'll need to work out the distance between the cutter edge and the edge of the base plate. You could probably cut the whole thing out with just the router, but you'd want a carbide spiral bit for that.
This will leave you with rounded corners which you could either square up or you could round the corners of the other peice of ply.
I bet someone here as an easier way.
gav is offline
post #4 of 13 (permalink) Old 11-27-2009, 08:45 AM
Honored Member
harrysin's Avatar
First Name: Harry
Originally Posted by kingnerk View Post
Hi,
Cheers!
Neil
Neil, in spite of the router being my main tool, I wouldn't use it to solve YOUR problem. Study these shots from one of my earlier threads and you will see that by cutting four pieces on the table saw then gluing them into a square you end up with a perfect, accurate square made very quickly. Using a router you would need a template (made as above!) and however small the cutter, the corners will still have to be squared. In your case you would cut two pieces 125 x 500mm and two pieces 125 x 250mm.
Harry
harrysin is offline
post #5 of 13 (permalink) Old 11-27-2009, 10:33 PM
First Name: Duane
Jig saw and a straight edge, then route a rabbit with the same straight edge being careful to stop on your mark and chisel the corners square.
The only other way I see to do it with out using a chisel and a router would be to make a face frame and lay it over another frame with the square slightly smaller to create your rabbit. Like making a face frame on the carcass of a cabinet. Then glue it and finish nail it in place.
Duane867 is offline
post #6 of 13 (permalink) Old 11-27-2009, 10:47 PM
Inlay kit, will do a nice job also
- Harbor Freight Tools - Quality Tools at the Lowest Prices
You can also use the brass guide you have on hand ( 7/16" ) and a 1/4" router bit, for the deep inlay jobs..or to cut out patterns,etc.
http://www.leevalley.com/wood/page.a...=1,43000,51208
post #7 of 13 (permalink) Old 11-27-2009, 11:05 PM
First Name: Duane
You still have to chisel those pesky rounded corners square though.
Duane867 is offline
post #8 of 13 (permalink) Old 11-27-2009, 11:12 PM
True,,but with the 1/8" bit ,it's hard to see the round corners...
1/16" radius.... plus the part will fit in just right and tight ..
post #9 of 13 (permalink) Old 11-27-2009, 11:13 PM
First Name: Duane
True enough
Duane867 is offline
post #10 of 13 (permalink) Old 11-30-2009, 03:08 AM Thread Starter
First Name: Neil
Hi, thanks for the replies,
I will let you know how I get on.
Bobj3 - can you just explain how the inlay kit works? it looks very interesting but i cant see how it works!
cheers
kingnerk is offline
Human Verification
Router table plates VS a hole in some wood? nikki1492 General Routing 17 06-15-2009 09:26 AM
Portable router table msjenkins Table-mounted Routing 3 01-26-2009 01:29 AM
Dust collecting the portable router reible Portable Routing 15 05-04-2006 01:31 PM
