Go Back   Router Forums > Routers > Portable Routing
Portable Routing Discussion area on the Portable Router and its applications. Bob and Rick say, "If the piece is bigger than the router then chances are it should be routed with the portable router."
Thread Tools Display Modes
Old 11-16-2005, 07:09 PM   #1
FrankAZ
FrankAZ is on a distinguished road
Question Routing LOTS of masonite ?
Greetings from Arizona,
Can anyone recommend what type of bit will work well for template routing shapes out of 1/8" or 1/4" masonite in a production level situation ?
I'll be using a handheld 2 HP plunge router (DW618PK) with a 1/4" or 1/2 collet. The bit diameter is of no particular importance to my project, but I'm guessing a 1/2" shank bit (maybe a 1/2" cutter too?) would be beefier and less likely to bend or chatter ? Maybe a spiral, or multi spiral bit ? Up-cut ? Down cut ? Straight bit ?
I'd also appreciate info on where to get a good deal on the recommended bit.
Thanks in advance,
Frank
FrankAZ is offline   Top - Reply with Quote
Old 11-16-2005, 07:27 PM   #2
kp91
Forum King
kp91's Avatar
First Name: Doug
If using a template guide bushing, a 1/2 in spiral with a half inch shank should last quite a while. Masonite, MDF, particleboard, etc. can be hard on bits, but a good quality solid carbide spiral should serve you well.
Some examples:
https://holbren.com/home.php?cPath=2...bc00195886eb42
http://pricecutter.com/product.asp_Q_pn_E_P11-1501
http://www.routerbits.com/cgi-router...186894_23797+9
If you are going to follow a template using a bearing (not recommended for doing a lot of pieces in my opinion) a quality flush trim bit with some shear angle will work ok. The fine dust from masonite might gum up your bearing on that bit however.
Hope this helps,
1 John 1:9
Freehand routing Visteonguy General Routing 50 09-08-2008 01:26 AM
Dovetail routing R-Man General Routing 4 10-11-2007 09:14 AM
Dust Colection for routing Dados KentWW Table-mounted Routing 3 01-10-2007 03:18 PM
Routing Template Verlin Garrett Jigs and Fixtures 5 02-06-2006 04:43 PM
Routing end grain Pop_pop1 Table-mounted Routing 8 09-22-2004 01:24 PM
