| | #1 |
| Registered User | Greetings from Arizona, Can anyone recommend what type of bit will work well for template routing shapes out of 1/8" or 1/4" masonite in a production level situation ? I'll be using a handheld 2 HP plunge router (DW618PK) with a 1/4" or 1/2 collet. The bit diameter is of no particular importance to my project, but I'm guessing a 1/2" shank bit (maybe a 1/2" cutter too?) would be beefier and less likely to bend or chatter ? Maybe a spiral, or multi spiral bit ? Up-cut ? Down cut ? Straight bit ? I'd also appreciate info on where to get a good deal on the recommended bit. Thanks in advance, Frank |
| | #2 |
| Marine Engineer Forum King | If using a template guide bushing, a 1/2 in spiral with a half inch shank should last quite a while. Masonite, MDF, particleboard, etc. can be hard on bits, but a good quality solid carbide spiral should serve you well. Some examples: https://holbren.com/home.php?cPath=2...bc00195886eb42 http://pricecutter.com/product.asp_Q_pn_E_P11-1501 http://www.routerbits.com/cgi-router...186894_23797+9 If you are going to follow a template using a bearing (not recommended for doing a lot of pieces in my opinion) a quality flush trim bit with some shear angle will work ok. The fine dust from masonite might gum up your bearing on that bit however. Hope this helps,
| Freehand routing | Visteonguy | General Routing | 50 | 09-08-2008 01:26 AM |
| Dovetail routing | R-Man | General Routing | 4 | 10-11-2007 09:14 AM |
| Dust Colection for routing Dados | KentWW | Table-mounted Routing | 3 | 01-10-2007 03:18 PM |
| Routing Template | Verlin Garrett | Jigs and Fixtures | 5 | 02-06-2006 04:43 PM |
| Routing end grain | Pop_pop1 | Table-mounted Routing | 8 | 09-22-2004 01:24 PM |
