| | #1 |
| Registered User New Member | I have two Hitachi M12V routers which I purchased after watching the Router Workshop on tape. One is for plunging and one is table mounted. The columns have begun to stick or stickslip on both of them. I have tried cleaning them and lubing them with Top Cote Brand lube. I even tried Johnsons Wax. Works for a short time and then the sticking returns. They both worked very well when new. I don't have more than 20 hours in total on both units. Does anyone know a cure? Thanks in advance for any help. |
| | #2 |
| Registered User Supreme Forum King | I had this issue with another router brand and found the answer when I purchased a router razer...... STP oil treatment found in your auto parts store or "X-mart" store. This was big back in the '60-'70 they had an ad on TV where this big guy would try to hold this screw driver blade that had been dipped in STP oil treatment.... Anyway they mentioned it and I hadn't thought about that stuff in years but when out and found some and that was last spring... still moving slick as can be. Ed |
| | #3 |
| Registered User Forum King | Check your columns for Spanner dents Tom |
| | #4 | |
| Registered User New Member | Quote:
| | #5 |
| Registered User Supreme Forum King | For those of you who might be questioning the STP information I have posted or dismissed it because you thought I was making this up. Here is the link to the Router Razer pages... this is a pdf file so you will need a reader. See item 4. http://www.routertechnologies.com/in...man%20pack.PDF I can tell you that it has worked for me. Ed |
| | #6 |
| Registered User Forum Geek | I was going to mention that it would attract dust, until I read the article and noticed that it indicates that it will attract dust. Just how bad is the dust situation when using STP? I'll never dispute the slipperiness of STP, but I'm wondering if a dry lubricant, such as graphite or even a simple wax candle, might be just as effective. Anyone tried a dry lube on the posts? Brian
__________________ A married man should forget his mistakes. There's no use in two people remembering the same thing! |
| | #7 | |
BTW I use to wax the shafts and that took a lot more time then what it takes the STP way. Ed | |
| plunge router? | gweissbock | Tools and Woodworking | 5 | 07-31-2008 11:52 PM |
| Mixing Bosch 1617 Router fixed base with Craftsman professional router | sf_basilix | Starting Off | 5 | 01-21-2008 09:54 AM |
| Motorized Router Lift - Eagle Lake Style | johnwnixon | Table-mounted Routing | 10 | 09-13-2007 07:59 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest - VOTING STAGE!! | Mark | Contests Archive | 13 | 11-05-2006 03:23 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest!! | Mark | Contests Archive | 72 | 10-01-2006 01:02 PM |
