Help
Go Back   Router Forums > Routers > Portable Routing
adjusting depth how to figure out the right depth
This is a discussion on adjusting depth how to figure out the right depth within the Portable Routing forums, part of the Routers category; Hello everyone, I'm super new to useing a plunge router! I have figured out How ...
Old 02-06-2010, 01:20 PM   #1 (permalink)
CFLfan is on a distinguished road
Default adjusting depth how to figure out the right depth
Report Post Report This Post!
Hello everyone,
I'm super new to useing a plunge router! I have figured out How to adjust the depth. But How do figure the right depth to adjust to? Besides making a ton of cuts and run out of wood.
May it will help if I explain the project i'm working on.
Its a game board 2'x2' 3/4in thick MDF. I want to use the half inch round for the top and bottom surface.
So on scrap material I've done the top looks good. Then I flip it over and do the bottom. When I do this the bootom cuts more then half way wich messes up the top cut.
Ive adjusted the depth to cut only half the thicknes of 3/4 but it doesn't seem to be nearly enough.
Is there a trick to get tem to line up do I need to switch to 1/4in round?
Thanks in advance for any tips
Cflfan
CFLfan is offline
Old 02-06-2010, 01:51 PM   #2 (permalink)
First Name: Joe
cbsjoez1935 is on a distinguished road
Hi Mike,
I think your problem is you are not using the right size roundover bit for what you appear to want to do and that is to put a complete rounded edge on your 3/4" thick board. To do what you want, I have two suggestions:
1. Use a 3/4" bull nose bit and gradually work it to get the edge you desire without having to flip over the board.
2. Use a 3/8" roundover bit (1/2 the diameter of the thickness of the wood you are working with), do one side to get half the round, flip the board over and complete the full round.
I hope this helps.
Joe Z.
JoeZ If you never made a mistake, you never tried anything
cbsjoez1935 is offline
Old 02-06-2010, 02:31 PM   #3 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
Hi
The trick is not to use the bearing on the bit.. you can use your router table with the fence in place if you don't have one use the pop on fence that came with your router.. or you can made a quick one to do the same job..
Originally Posted by CFLfan View Post
Hello everyone,
Cflfan
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
Many Router Tips from RWS
http://www.routerworkshop.com/router_tip_glossary.html
http://www.routerforums.com/email-ro...-members-only/
Router Tables ,Ready to use
http://www.rt1000.com/
http://rt1000.com/_wsn/page2.html
Bob J.
Old 02-06-2010, 06:22 PM   #4 (permalink)
Cassandra's Avatar
First Name: Cassandra
Cassandra is on a distinguished road
Hi Mike:
Welcome to the router forums!
Which CFL team do you root for?
Cassandra
Please Please Please edit your profile with a name and location so we can better assist you and make for a friendlier forum.
Cassandra is offline
PC 4212 Bit Depth zach Jigs and Fixtures 9 11-17-2009 11:24 AM
trouble adjusting the depth of my Craftsman router JohnnyB60 General Routing 7 06-19-2009 06:13 PM
Ridgid R2930 (fixed and plunge base routee) xplorx4 Tool Reviews 13 03-12-2009 02:20 AM
Depth adjusting ring doesn't turn. waynecathy33 Introductions 4 11-17-2008 11:35 PM
pc 890 series depth adjustment rabuckner General Routing 4 04-10-2005 01:20 PM
