Go Back   Router Forums > Routers > Portable Routing
Thread Tools Display Modes
Old 09-27-2004, 06:48 PM   #1
paulcomi
Sr. Member
paulcomi's Avatar
paulcomi is on a distinguished road
Default Edge guide for my PC 890
I don't have an edge guide yet and I'm wondering if I should buy one of the ones made by Porter Cable or just make one myself. I'm also curious to know how useful you find one if you use one.
paulcomi is offline   Top - Reply with Quote
Old 09-27-2004, 10:09 PM   #2
kp91
Forum King
kp91's Avatar
I have the old porter cable edge guide, left over from my 693 router, and it works on the 890. I have also used a home-made one in the past, and they both work the same. I have never tried the real expensive porter cable one, and I can't think of a reason that I would need it.
I find the edge guide handy for use on routing the edges of pieces where the router wants to wobble to one side and dig into the work. Any 2 contact point edge guide will work, or doublestick taping a block to your sub base so it will provide support.
The hardest part I had making a home made edge guide was coming up with the screws to clamp the rods into the router base.
One handy edge guide I have is the square baseplate for my router. It is an excellent surface to ride on clamp-n-edge guides for cutting dados.
Hope this helps
1 John 1:9
Old 09-28-2004, 12:39 AM   #3
paulcomi
Sr. Member
paulcomi's Avatar
You gave me an idea....If you used a square base plate and slotted two slots you could have a sliding fence edge underneath with a couple lock knobs and have a very workable home made edge guide. do you think I'd be losing anything by not just buying one?
Old 09-29-2004, 07:40 AM   #4
kp91
Forum King
kp91's Avatar
I don't think so. Plus, I always like coming up with my own solutions to workshop challenges. (that and I am cheap, and don't like to part with any money I don't have to)
http://www.woodworkingtips.com/etips/etip063000ws.html
http://popularmechanics.com/home_imp...s/index5.phtml
http://www.patwarner.com/edge_guide.html
These should give you a couple of ideas
1 John 1:9
Old 09-29-2004, 09:41 AM   #5
paulcomi
Sr. Member
paulcomi's Avatar
The first link is a good choice if I made it out of lexan/plexiglas. It really does what I need/want. I guess it comes down to the advantage of a pc edge guide or one like it that it can slide in and lock without having to remove the router base. I do like that first one a lot though. Thanks for posting that link.
Old 10-25-2004, 01:54 AM   #6
Putzger
Member
Putzger's Avatar
Putzger is on a distinguished road
Send a message via AIM to Putzger
I have had the #42690 micro-adjust edge guide for my 690 router(s) for quite some now and frankly, it doesn't get all that much use. However, the $48 it set me back those few years ago was suddenly self-justified today when I had a long highly-precise multi-level slot to route out.
I was making the long 1/4" wide slot through a sheet of 3/4 finished particle board -- the through-slot needed a 1/4" deep shoulder on each side.
(Envision a 1/4" deep by 7/16"-wide slot with a 1/4" wide slot 3/4" deep sliced dead down the center for an overall length of 28".)
Without the micro-adjust guide, I could not have pulled it off.
Your smileage might well vary :-)
Steve
www.apachetrail.com/ww/
Mesa, AZ
Putzger is offline   Top - Reply with Quote
Old 10-25-2004, 06:21 AM   #7
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
The best edge guide I have seen and used on my routers is the one manufactured by Micro Fence, they make them adaptable to most any router, and also have a circle
guide to add to it they work great. But they are a bit pricey.
Good luck, Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Wanting an edge guide xmonday General Routing 2 05-14-2008 07:46 PM
Rockler edge guide Falegname General Routing 5 12-02-2007 01:54 PM
Router edge guide mwm500 General Routing 3 11-09-2006 07:30 PM
Router Edge Guide for Hitachi Router cdub101 Introductions 2 07-05-2006 10:45 PM
Rockler Router Edge Guide reds_21 Jigs and Fixtures 1 02-06-2005 10:25 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109
