Go Back   Router Forums > Routers > Portable Routing
Rate This Thread - Advice Needed.
Thread Tools Display Modes
Old 09-27-2004, 07:24 PM   #1
denisd
Forum Fanatic
denisd's Avatar
denisd is on a distinguished road
Default Advice Needed
I need to route a "slot" 8" wide 40" long and either 1/4 or 3/8" deep into a 3/4" board. I have tried it on the table and it works fairly well. I would like to know if I can use my plunge router with a guide using a 1 1/4" bottom clening bit. Will this be safe to use as long as I have enough support for the bottom of the router base. I will be using a Porter-Cable 890 router and a 7" base plate purchased from Oak Park. Any help would be appreciated.
denisd
denisd is offline   Top - Reply with Quote
Old 09-27-2004, 08:58 PM   #2
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
denisd
If we are going to use a 1 1/2" template guide, 1 1/4" bottom cleaning router bit and a pattern to make this 8" X 40" slot.
I would assume the measurements are important. I would use the 1 1/2" guide positioned in a slot pattern that is width of the guide and 40" in length: using reible's tables to figure the pattern size.See post
You need to understand reible's table and be able to figure the sizes for the pattern. This slot pattern can be positioned on one side of the 8" slot then used to cut the first groove with full support of your base and guide, move the slot pattern 5/8" to stay on the cutting side of the 1 1/4" router bit fasten and cut the next piece of material. Move, fasten and cut until you have your 8" wide slot.
Hopefully this will help, please let me know if you need more info.
Rick and Bob
The Router Guys
Old 09-28-2004, 05:10 AM   #3
denisd
Forum Fanatic
denisd's Avatar
Thanks for the help. I was mainly concerned with the size of the bit and the guide being used safely in a plunge router. It appears that Rick and Bob think it is safe so here I go.
denisd
Old 09-28-2004, 01:55 PM   #4
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
Keep your cuts on the right side of the router bit and work safely.
Rick and Bob
The Router Guys
Cnc advice needed mderzio CNC Routing 5 04-09-2008 07:32 AM
need advice for inserting rosseau router plate into bench dog promax cast iron table sf_basilix Table-mounted Routing 7 02-21-2008 06:00 PM
Router selection help needed robdunstan Table-mounted Routing 19 02-14-2008 03:37 PM
Bench Dog Advice needed LonePalm Table-mounted Routing 1 01-13-2008 01:49 PM
Bandsaw advice needed Bob Tools and Woodworking 7 06-07-2005 03:15 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
