Square corners - Router Forums
post #1 of 95 (permalink) Old 05-01-2010, 12:16 AM Thread Starter
Honored Member
harrysin's Avatar
First Name: Harry
Default Square corners
A thought has just popped into my head, how do professional door makers make the patterns with square corners. I know that they use CNC machines, but that in itself doesn't answer the question. I wonder if multiple cutters are used, finishing the internal corners with a "V" cutter.
Harry
harrysin is offline
post #2 of 95 (permalink) Old 05-01-2010, 01:57 AM
Hi Harry - with a CNC I think they overshoot a bit, lift out of the work and replunge in going the next direction.
John Schaben
jschaben is offline
post #3 of 95 (permalink) Old 05-01-2010, 02:58 AM Thread Starter
Honored Member
harrysin's Avatar
First Name: Harry
Wouldn't that still leave round corners John?
Harry
harrysin is offline
post #4 of 95 (permalink) Old 05-01-2010, 08:21 AM
First Name: Swallow
Send a message via MSN to Swallow Send a message via Yahoo to Swallow
What kind of doors are you talking about Harry?
Retirement is easy, but You really have to work at it.
Swallow is offline
post #5 of 95 (permalink) Old 05-01-2010, 09:29 AM
Hamlin's Avatar
First Name: Ken
Hi Harry,
It would probably follow along the same principles as the following links.
YouTube - Drilling a square hole! (www.howround.com)
YouTube - square hole drilling
Ken
"A VETERAN"
Hamlin is offline
post #6 of 95 (permalink) Old 05-01-2010, 09:54 AM Thread Starter
Honored Member
harrysin's Avatar
First Name: Harry
Excuse the lousy photo., but if you look at it carefully, you'll notice that the outside corners are perfectly square.
Harry
harrysin is offline
post #7 of 95 (permalink) Old 05-01-2010, 09:58 AM Thread Starter
Honored Member
harrysin's Avatar
First Name: Harry
Originally Posted by Hamlin View Post
Hi Harry,
I can't see that Ken, in spite of it being very interesting, there really are some clever people out there. I hope all is well in the Hamlin household.
Harry
harrysin is offline
post #8 of 95 (permalink) Old 05-01-2010, 10:28 AM
Hi Harry
The only way I see how they do it , is with the stamp mold type,(just like a big waffle iron press ) that's to say when they make the stock (MDF) they stamp them out with a 200 ton press.
When they make the stock (MDF) it looks like dry oat meal..
post #9 of 95 (permalink) Old 05-01-2010, 10:55 AM
rwyoung's Avatar
First Name: Rob
Probably not practical for "inexpensive" CNC machines but if you add another axis to allow the cutting bit to be tilted, you can mill a square corner with a V-cutter. The bit is tipped such that one side is parallel to the cut direction and the tip is in the corner. Now you can cut square. And technically, it still isn't square, the tip of a V-cutter is till a bit rounded but close enough for government work.
An alternative to tilting the bit is to tilt the work piece but ultimately this all means more steps, more complexity and more cost so I doubt it how its done in production cabinetry.
p.s. - my post is referring to INSIDE corners. If you mean an outside corner, you will get a square corner as the bit transitions from an "X" travel to a "Y" travel because all the cutting happens just at the little tangential point. However due to some slop in the equipment it can and probably will round over a little bit.
rwyoung is offline
post #10 of 95 (permalink) Old 05-01-2010, 11:44 AM
Hamlin's Avatar
First Name: Ken
Default For Harry
Take a look at these vids. It becomes clear soon enough. Yes, things are quite well here, especially that it's stopped raining... for now.
YouTube - Square-Hole Drill in Three Dimensions
YouTube - Drilling a Hexagonal Hole
Ken
"A VETERAN"
Hamlin is offline
Human Verification
90 deg. Corners kolias General Routing 14 01-10-2009 12:35 PM
Keeping something square when gluing? ygdrasil54 Starting Off 5 10-30-2006 05:59 PM
Inside corners on letters petersenj20 Sign Making 3 08-06-2006 09:32 PM
Square fence Drick General Routing 5 03-30-2005 03:17 PM
