Go Back   Router Forums > Routers > Portable Routing
Portable Routing Discussion area on the Portable Router and its applications. Bob and Rick say, "If the piece is bigger than the router then chances are it should be routed with the portable router."
Thread Tools Display Modes
Old 01-29-2006, 02:45 AM   #1
fancyfull
New Member
fancyfull is on a distinguished road
Default centering guide for mortise
I was wondering (as a newbee to the router) where I might get info/product discriptions of the base plates with the centering bearings on the corners that were used to center mortises
fancyfull is offline   Top - Reply with Quote
Old 01-29-2006, 02:59 AM   #2
Pop_pop1
Forum Fanatic
Pop_pop1 is on a distinguished road
Hi Fancyfull, and welcome aboard.
You will find these baseplates to fit juat about any router at www.oak-park.com
PopPop
If it's worth building, It's worth building well.
poppop@routerforums.com
Pop_pop1 is offline   Top - Reply with Quote
Old 04-14-2006, 12:21 PM   #3
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Fancyfull
Not sure if you are still looking for the bearing to make a "mortises" jig.
You can get them from http://www.grizzly.com
Parts number(s) G3847,G3845 and many other sizes listed in the Cat.(replacement bearing for router bits)
You can make a quick base plate with a 1/4" clear plastic stock 8" x 8" and hole saw or a 1 1/2" Forrest Bit.
Cut the stock Sq. and on ea.corner drill a hole to fit the bearing I.D.(on center with the 1 1/2" hole) then take your base plate off your router and line it up with the center hole and drill the mount holes to it to your router motor.
The best way to line it up is to use a 1 1/2" plug with a 1/4" hole in the center of it and then snap it in the router base plate,then drill a 1/4" hole in the new base plate,this will line the parts up on center, then drill the 1 1/2" hole in the new base plate.
If you take your time you can you can use Forrest bits&hole saw and put in a 1 3/16" hole in the base plate to hold the brass bushing guides ( H3143 ) then just put the stock base plate back in the box for your router.
The 8 " x 8" base plate works great for many other jigs and gives you more control over the router.
Hope this helps
Bj
Old 04-18-2006, 09:40 AM   #4
Gilbear
Supreme Forum King
Gilbear's Avatar
Gilbear is on a distinguished road
I'm wondering if Fancyfull might actualy be looking for a baseplate that centers the bit on a workpiece edge (rather than a baseplate centering set-up)?
If so, take a look at this link, I believe it accomplishes what you're after -
http://www.woodworkingtips.com/etips/etip032301wb.html
Gilbear is offline   Top - Reply with Quote
Old 04-18-2006, 10:45 AM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Bob & Rick made a jig ,that Bob he used to make center mortises quick and easy by placing bearing on the corners of the base plate.
See quick jig below.
I thinks thats what he was taking about.
Bj
Old 04-18-2006, 11:48 AM   #6
Gilbear
Supreme Forum King
Gilbear's Avatar
Mornin' BJ!!
I think I'm feeling slow, but not sure that I understand the jig picture.
I guess was thinking something more along these lines (from the above link):
Your pic looks simpler ... I'm just not understanding how it works.
centering-guide-mortise-centering-plate-2.gif  centering-guide-mortise-centering-plate.gif
Old 04-18-2006, 12:39 PM   #7
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Gilbear
The stock you want to put the mortise in is locked in jig with a slide wedges and the router base is set on top and turned all the way to the right until the outer bearings rub on the stock this centers the bit on dead center, then just plunge down and pull then router to you ,it takes a time or two if you are using 3/8" X 1.250 deep slot.
It can be used for 1/4",3/8",1/2" mortise slots and they come out right on center every time.
You can use the router table also but it's a bit tricky to set it up for center when you use 3/4" to 2" stock and plunge it down but this way it's done in a flash .
And it works great and it's quick and easy.
The out side parts of the jig need to be the same height as the stock, this helps the slot stay at a 90deg. to the stock and a place to support the router.
If you are using a 1 1/4" x 2" stock it will take a space in the jig to offset the stock so the slotts come out right, and right and left side thing.
I don't recall when Bob made this jig but it's a great one.
http://www.routerforums.com/jigs-fixtures/2641-mortise-tenon-jig-plunge-router.html
Bj
Centering a collar guide S Bolton Jigs and Fixtures 2 12-03-2007 03:33 PM
Inlay Guide Bushing and base plate Doyle Portable Routing 3 06-07-2007 10:25 PM
Porter-Cable template guide no where to be found jnam Portable Routing 5 07-21-2006 08:54 PM
Centering nonadjustable guide bushings banjopicks Table-mounted Routing 4 03-10-2006 12:06 AM
Porter-Cable template guide no where to be found jnam Jigs and Fixtures 3 02-21-2006 08:15 AM
