| | #1 |
| Registered User New Member | I have a project and would like input. I need to build a template to assist putting additional vents in the soffit of my house. I plan to use a small trim router to cut a 6x15 hole about every 5 feet. How to hold the template in place while I cut upsidedown. Any input will help. Sorry Wrong forum Last edited by JMRagan; 02-05-2006 at 07:36 PM. Reason: Wrong Forum |
| | #2 |
| Registered User New Member | You could try this idea,make a template from 1/4" plywood, make the cut out big enough to allow for the router base and use a plung bit,Attach with double sided tape or small screws that would be covered by your grill if you plan on using one.I use double sided carpet tape works well.Hope this helps the Restorer |
| | #3 |
| The Router Guys Forum King | I think small screws are the best bet. You don't want this template moving around.
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. |
| Looking for a CAD file to make a template | tearen | Guide Bushings and Templates | 1 | 06-11-2008 11:10 AM |
| Mortise Template | JDługosz | Jigs and Fixtures | 14 | 09-27-2007 02:32 AM |
| Template Routing | FlyFAmerica | Portable Routing | 8 | 01-22-2007 09:57 PM |
| Make a template to create a filler piece? | Ric Naff | Jigs and Fixtures | 3 | 01-12-2006 08:56 PM |
| Template, how to make? | smacmullin | Jigs and Fixtures | 2 | 11-08-2005 05:52 PM |
