Routing deep mortise - Router Forums
post #1 of 18 (permalink) Old 08-31-2010, 10:42 AM Thread Starter
First Name: Dale
I am in the process of building a workbench and have eight 2-1/4" x 1-1/2" x 3" deep mortises I need to cut. Of the many ways I could go about producing these mortises, it seems using my plunge router would result in cleaner and more accurate mortises.
How would you recommend I go about routing a deep mortise: process?, type of bit (most plunge bits I have seen don't have the length to cut that deep)? and where to get such a bit if one were available?
Thanks,
Dalec
Dalec is offline
post #2 of 18 (permalink) Old 08-31-2010, 10:53 AM
Hi Dalec
I would suggest using a spade bit to hog out most of the wood and then use the bits below to clean up the hole with a template and/or brass guide on your plunge router base plate.
1 pc 1/2"SH 2-1/2" Blade Top Bearing Trim Router Bit - eBay (item 130425183413 end time Sep-25-10 15:53:21 PDT)
1 pc 1/2" SH 3" Blade Extra Long Straight Router Bit - eBay (item 130426568658 end time Sep-29-10 16:37:46 PDT)
Thanks,
Dalec
post #3 of 18 (permalink) Old 08-31-2010, 11:03 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Hi dalec
3" bits are available, but you will probably find they exceed the travel of the plunge so would make using them for such deep mortising complicated. Ones like 1 pc 1/2" SH 3" Extra Long Flush Trim Router Bit - eBay (item 130426115276 end time Sep-05-10 11:23:34 PDT) with the bearing removed might do. Better still
I must stop looking on that web site. There are too many temptations !
Cheers
Peter
istracpsboss is offline
post #4 of 18 (permalink) Old 08-31-2010, 11:04 AM Thread Starter
First Name: Dale
Thanks Bobj3.
I got stuck in routing out the entire mortise. Had not even thought about drilling out most of the waste before using a trim bit to clean up the mortise.
Dalec
Dalec is offline
post #5 of 18 (permalink) Old 08-31-2010, 11:05 AM
Country: Croatia
First Name: Peter
Snap ! I was looking while you were writing, Bob !
Cheers
Peter
post #6 of 18 (permalink) Old 08-31-2010, 11:13 AM Thread Starter
First Name: Dale
Peter,
Thinking with bearing guided trim bits, that I could gain some additional depth by using two different length trim bits so I can step my way down to a deeper mortise or use differing thickness template material and step down that way. Don't know if this would gain me much more depth however.
Dalec
Dalec is offline
post #7 of 18 (permalink) Old 08-31-2010, 12:18 PM
Hi Dalec
Once you clean out the hole down ,than route the hole out to say 1 1/2" the rim of the hole will give you a nice edge to ride on with the bearing or the brass guide template..I have push my bit to 3 1/2" deep without any error..
Peter,
Dalec
post #8 of 18 (permalink) Old 08-31-2010, 04:46 PM Thread Starter
First Name: Dale
Thanks Bobj3 and Peter.
I appreciate the suggestions and can see the solution.
Dalec
Dalec is offline
post #9 of 18 (permalink) Old 09-06-2010, 01:00 PM
First Name: pat
Key here is good and repeatable/indexable fixturing; without it , forget my proposal.
Indeed drill out most of the waste. Then rout all mortices with with generic HSS cutter maybe 1/2 x 2-1/2 long. Stay inside of the net dimensions x ~1/16" all around.
Now change to long (4-5" OAL) SC up-spiral or another longer HSS straight bit to waste to depth and width. All stock most go back into the fixturing just the way it came out in step one. Note this longer cutter will already have an inch or so of projection whence the motor head is all the way up the tubes. So take these first, tho modest cuts, with care.
Quillman is online now
post #10 of 18 (permalink) Old 09-13-2010, 09:01 AM Thread Starter
First Name: Dale
Thanks Quillman.
I really appreciate the responses I have gotten. It is like talking over a problem with a number of people in person and as the discussion continues suggestions begin to form into a process that will work for me. Quillman, even when I thought I had it figured out, your description of how to go about it, added to my thinking about what is now my approach.
Thanks everyone who had contributed your suggestions.
Dalec
Dalec is offline
Human Verification
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 10:33 AM
CNC routing as first routing experience ianthehenry CNC Routing 23 04-25-2012 05:24 AM
Deep Mortise Question mbg Tools and Woodworking 13 09-22-2009 03:12 PM
How deep is to deep? jschaben Router Bits - Types and Usage 8 08-13-2009 10:50 AM
TS / Router / Mortise Combo PART1 kolias Jigs and Fixtures 1 05-04-2009 07:52 AM
