Go Back   Router Forums > Routers > Portable Routing
Portable Routing Discussion area on the Portable Router and its applications. Bob and Rick say, "If the piece is bigger than the router then chances are it should be routed with the portable router."
Thread Tools Display Modes
Old 03-14-2006, 08:41 PM   #1
bike
New Member
bike is on a distinguished road
Default jointer??
hello all, new here and already learning alot, now to my question and i hope i can get it accross without two much confusion.
i need a jig for makeing the edges of two different boards come togather like a pattern(i think thats how i want to say it)i have seen this jig in a book that a friend from work has but as im laid off im not able to get ahold of him. it wasent that complicated, you put the boards in from opposite directions..make a pass with the router on the first one, move the seconed board up and make the second pass useing the same "fence" as u did with the first one...the two boards should be identical when done..pretty simple..but i cant figure it out without at least a pic or something.
thanks in advance
bike is offline   Top - Reply with Quote
Old 03-15-2006, 12:40 AM   #2
GoonMan
Forum Geek
GoonMan's Avatar
First Name: Randy
GoonMan has a little shameless behaviour in the past
thanks in advance
Hello bike, Welcome to the RouterForums
Are you talk about a flush trim Jig?
Regards
Randy
PC Support Forums, Free on line virus Scan, The Parasite Fight,
Subratam.org -> Kill Spyware Forums A.S.A.P. Proud member since 2004 ~
GoonMan is offline   Top - Reply with Quote
Old 03-15-2006, 03:27 AM   #3
TerryO
Jr. Member
TerryO's Avatar
TerryO is on a distinguished road
http://ca.oak-park.com/catalogue.htm...-&product=F020
TerryO is offline   Top - Reply with Quote
Old 03-15-2006, 07:59 PM   #4
bike
New Member
Originally Posted by TerryO
i guess u could call it that..im not sure...i call it the poor mans jointer, i figured it out today and made it, and the best part is...it works!!!! all it does is make the edges of boards the same so when u mate them they go togather perfectly, and since my table saw is basicallly junk...and i dont have a jointer this is a pretty good alternative to good clean joints for makeing panels up on.
Old 03-16-2006, 12:03 AM   #5
GoonMan
Forum Geek
GoonMan's Avatar
First Name: Randy
Hello bike,
I understand now. I use my Split Router Fence which is reversible for jointing and a long 1/2" Shank 1/2" Straight bit in my router table, then I use a Reversible Glue Joint bit to join the boards for a table top or Door Panels..
Regards
Randy
Old 03-16-2006, 12:07 AM   #6
Dr.Zook
Supreme Forum King
Dr.Zook's Avatar
First Name: Dave or "Doc"
Dr.Zook is on a distinguished road
Send a message via Skype™ to Dr.Zook
bike, I know the jig you are referring to. I have seen it in one of my books. I looked in two of them but can't find it. i will keep searching tho and will let you know if and when I find it.
Dave
the "Doctor"
Dave
the "Doctor"
Dr.Zook is offline   Top - Reply with Quote
Old 03-16-2006, 02:39 AM   #7
bike
New Member
id like to see that again...like i said i did come up with something that does work would like to see how its supposed to be...if i can figure out how ill post of pic or two of it.
Old 03-16-2006, 07:29 AM   #8
del schisler
Forum Geek
del schisler is on a distinguished road
i use a flush trim bit and this fence 19" Long polyethylene Router Jointer Fence
Infeed is 1/16" narrower to joint the edges of your wood when you get it set up right it work's better or just as good a good tuned jointer but i like the flush trim better del schisler
http://us.oak-park.com/catalogue.htm...-&product=F020
del schisler
del schisler is offline   Top - Reply with Quote
Old 03-16-2006, 10:28 AM   #9
jerrymayfield
Forum Geek
The jointer fence (I use a piece of plastic laminate) will work for edges,but it is difficult to level the faces without a jointer.
Regards
Jerry
Old 03-21-2006, 07:15 AM   #10
del schisler
Forum Geek
Regards
Jerry
i have both fence's 1 is off set to the infeed and the other 1 is just streight accross no off set
i use my planer first than do the flush trim bit it is quick eather way works del schisler
del schisler
Planer or Jointer angus Tools and Woodworking 10 04-21-2008 10:41 PM
Oak Park Beveled Jointer Jig tpyke Jigs and Fixtures 11 03-27-2008 10:16 PM
Jointer? Or Planer? Which one first? reikimaster Tools and Woodworking 26 09-27-2007 02:38 PM
Another jointer question. ryan.s Tools and Woodworking 10 05-08-2005 12:00 PM
Getting that new jointer Glenmore Tools and Woodworking 0 01-19-2005 09:43 PM
