Help
Go Back   Router Forums > Routers > Portable Routing
IconIt appears you aren’t a registered member of the Router Forums community. Why not spend less than a minute and register for the oldest and largest router and woodworking community on the web! Join in over 29,500 discussions with over 65,000 woodworkers. If you’re an experienced or beginner woodworker, your questions and knowledge is always warmly welcomed by our community. Register now for your FREE account!
Newly created router skis...
This is a discussion on Newly created router skis... within the Portable Routing forums, part of the Routers category; After studying the numerous posts on router skis, many from Harry and BJ, I have ...
Old 11-02-2010, 03:51 AM   #1 (permalink)
matt1710's Avatar
Country: New Zealand
First Name: Matthew
matt1710 is on a distinguished road
Default Newly created router skis...
Report Post Report This Post!
After studying the numerous posts on router skis, many from Harry and BJ, I have created my own. The cheeks aren't finished yet - they need a coat of something to prevent them absorbing moisture, and to make them more slippery. The cheek shape is an exact copy of Harry's, however the rod attachment method is certainly BJ's. Although I've yet to actually use them, they seem very good. I used 18mm MDF, the rods are 12mm stainless steel (very smooth), the slots were routed with a 12.7mm spiral - the excess there doesn't seem to have created any wobbliness. Haven't been able to find any star washers (at all!) - let alone some that will permit a 12mm rod through. BJ says the rods will slip down the cheeks without star washers - so I need to get my hands on some.
Observations thus far:
1. the springs are easy to tension using a Irwin quick clamp with the rubber 'shoes' removed. I simply put the plastic feet of the clamp on the two lock collars, tighten the clamp then tighten the allen key to lock the lock collar in place. The springs seem to make the entire setup very rigid.
2. The inside lock collar might get in the way of the rails on my camboard (yet to be created so I don't know yet) - depending on how high in the slots I set the rods. I could always use a lower profile rail (was going to use 18mm mdf) if it's a problem.
3. The Makita 3612C's handles butt into the cheeks when the rods are at the bottom of the slots - I might modify the cheeks to remove this issue, if it becomes an problem.
Matthew
PS - here are a few pictures...
Newly created router skis...-entire.jpg   Newly created router skis...-end.jpg   Newly created router skis...-inside.jpg   Newly created router skis...-springs.jpg
matt1710 is offline
Sponsored Advertisement - Register now to remove this advertisement.
** Please be sure to read our Disclaimer at the bottom of the page. **
These advertisements are only displayed to guests, register now for your FREE account on the worlds largest router and woodworking community!
Old 11-02-2010, 04:15 AM   #2 (permalink)
Country: Germany
First Name: Titus
Titus A Duxass is on a distinguished road
Top Job!
They look good.
Just give them a few coats of varnish to seal them.
This is my next task, I started with my cam board after finding 30 or so blindnuts and a piece of mdf for 1.20 euro.
Titus A Duxass is offline
Old 11-02-2010, 06:24 AM   #3 (permalink)
jw2170 has a spectacular aura about
Very nice, Matthew.
And I see you have the right router for the job...
Keep us up to date on progress
Sydney, Australia
jw2170 is offline
Old 11-02-2010, 08:26 AM   #4 (permalink)
harrysin's Avatar
First Name: Harry
harrysin is a splendid one to beholdharrysin is a splendid one to beholdharrysin is a splendid one to behold
Looking really good Matt. I'm eagerly awaiting for your report as to how well it works on a fairly heavy job like planing a rough block, also how long it takes to re-set the height making sure that all corners are the same height.
Harry
harrysin is offline
Old 11-02-2010, 09:51 AM   #5 (permalink)
bobj3 has a brilliant futurebobj3 has a brilliant futurebobj3 has a brilliant futurebobj3 has a brilliant future
HI Matt
Nice job
" absorbing moisture" " more slippery " use some Johnson Floor Was (paste in the yellow can ) about 3 or 4 coats will do the trick, just for kicks do the same thing to some scraps and than put some water on them and watch the water bead up and run right off and than slide the stock over the work bench and you will see it just slides right over it with almost no drag...plus when you cut the slots out for the handles you cab re-coat them easy, the MDF will soak the wax right up and lock into the wood..
Star washers, just make your own, washer,, cut it with the hack saw, in 4 or 5 spots on the washer, take pair of wire cutters and turn the washer parts to the right (all the same way )(Stainless steel works best ) it will not rust and is very strong,it's not spring steel but almost..
"inside lock collar" should be fine, yours look about the same size I used and the rods will keep them up and out of the way.
To set all the rods the same on the cheeks, I put a scrap block under the router let it rest and lock them all it place at one time..then pull the scrap block out and you are set to run..
Here's a small tip, drill a 1/4" hole in the center of the cheeks on the bottom side so you fit in a 1/4" x 3/4" dowel pin and you just made a great cir.jig. one jig for more than one job...like a great edge guide..by just dropping one of the cheeks down and adding a slide block to rods to keep the router level..
Looking forward to your feed back..
Just a quicker way to adjust the rods on the cheeks and compress the springs..all in one move, you can get one for about 8.oo dollars, small eng.repair parts supply store or auto parts store parts ,off the spin rack..I know the tool below will get Harry going, he will say what the hell is that, don't Americans know about wing nuts ? or what ..
see below. ▼
KD Hand Tools 379 Small Engine Valve Spring Compressor
Matthew
MANY,MANY help files on John's web site
http://legacy.woodshopdemos.com/menu2.htm
Sommerfeld Tools ,Videos
Old 11-02-2010, 12:21 PM   #6 (permalink)
gav
Country: Croatia
First Name: Gavin
gav is on a distinguished road
I'm thinking of finally getting around to making some skis myself now that I have a workshop space.
I think I have all the details I need except for one.
How often do ski users have the need to set up the router so it's not level within the skis ?
Seems to me it would be a rare need, so why have 4 different heights to adjust when you could just have 2 ?
gav is offline
Old 11-03-2010, 03:01 AM   #7 (permalink)
matt1710's Avatar
First Name: Matthew
Hi Bob
Thanks! Johnson Floor Wax - better than some kind of varnish, by the sounds of it? Should be easier to apply, that's for sure!
Will try making my own star washers...
One way to minimize the chances that the inside lock collar or washer will foul on the edge guide : lower profile edge guides. I cut two 20mm wide strips of 18mm thick MDF - however it does foul on the collar. I guess I could use something like 6mm ply edge guides - that way it would run under the collar/washer. The only risk is that the skis might jump over the low edge guide. Your thoughts?
Thanks for the tips re setting the heights, and the circle cutting jig - good idea!
One thing - I hate cutting corners with a bandsaw - see all those nasty saw marks on the mdf? That's after sanding them too! If I'd known how to cut the corners with the router, I would have done it.
Matthew
HI Matt
Nice job
see below. ▼
matt1710 is offline
Sponsored Advertisements. Register to disable this advertisement.
Old 11-03-2010, 03:03 AM   #8 (permalink)
matt1710's Avatar
First Name: Matthew
Hi Harry
Thanks! I'm looking forward to using them too - will let you know how they get on. It sounds like you're expecting them to slip... ;-))
Matthew
matt1710 is offline
Old 11-03-2010, 08:39 AM   #9 (permalink)
Hi Matt
Thanks and Your Welcome
The router is a great tool to get the corners nice and true and clean, I use a sandwich jig the norm on the router table it's just two 1/4" thick parts of MDF stock and some project stock, I make a sandwich so to speak,the 1/4" MDF is (bread) cut on the band saw than project stock is screwed inside of the 1/4" thick MDF, I push in the project board in (the meat ) and chuck up a trim router bit in the router table and buzz off the corners ,they come out very clean and no band saw marks at all and they are always just the same, I will some times remove some of the corners to make it easy on the skew trim router bit, I do like to use the bigger CMT trim bit ( 3/4" OD bit) most of the time buit I also like using the MLCS trim bit below also.
Spiral Flush Trim Router Bit
MLCS solid carbide router bits
Star washers are easy to make
You may to get some
UHMW Slick Tape
UHMW Plastic Sheets and Strips
http://www.routerforums.com/tools-wo...er-radius.html
Hi Bob
Matthew
Old 11-03-2010, 08:52 AM   #10 (permalink)
harrysin's Avatar
First Name: Harry
Get going mate, $30.00 plus about a million for transport, how much do you think it would cost to have the ends threaded, a LOT less than that.
Harry
harrysin is offline
Tags
no threaded rod, router skis
A beginners guide to making router skis harrysin Jigs and Fixtures 166 04-07-2013 09:28 AM
Router Skis....again Al Robins Lobby 48 05-10-2010 09:41 AM
New here burlboy Introductions 9 01-15-2009 11:53 AM
