Help
Go Back   Router Forums > Routers > Portable Routing
Planing with a Router
This is a discussion on Planing with a Router within the Portable Routing forums, part of the Routers category; Hi Joe Well here's a small update, it's 99% done but I did run into ...
LinkBack (2) Thread Tools Display Modes
Old 11-24-2006, 07:36 AM   #21 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
Report Post Report This Post!
Hi Joe
Well here's a small update, it's 99% done but I did run into a error that I need to fix today ,that is a out feed device, after removing stock it needs a small item on the out put side to get it to work right just like a jointer plus I want to add a fence to keep it sq. when I use it like a jointer, I think I'm going to use some black 1/16" thick vinyl stock on the out feed end.
I did rip the sand paper on the drum roller so I need to replace that today ,I wanted to see if I could jam the roller and see what would fail 1st. and now would be the time to fix it.
All in all I would give it 4 stars out of 5, I did make a error when I made the top part, I put the slot for the roller on the back side of the top and it should be in the center of the top but I was trying to fix the out feed on the top, when you remove stock you need someting to support the new size (thickness) so I made a out feed table top but it's a bit to low, the vinyl should fix that.
I will post a picture or two once I have the shop clean again I have wood and tools all over the place on this project.
Just a side note, I just got a copy of the Jasper Cir.jig and it's great little hole jig, my son had one at work and made a copy of it by drilling 126 holes in some 1/2" MDF stock.
Then once I got it from him I drilled 32 more holes, for a total of 158 so now it can do 5" to 18 15/16" .
Number 200 type
http://www.soundlabsgroup.com.au/pc/JA-200/Jasper/Sound
http://www.routerforums.com/jigs-fix...html#post35697
Bj
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
Many Router Tips from RWS
http://www.routerworkshop.com/router_tip_glossary.html
http://www.routerforums.com/email-ro...-members-only/
Router Tables ,Ready to use
http://www.rt1000.com/
http://rt1000.com/_wsn/page2.html
Bob J.
bobj3 is online now
Old 11-24-2006, 04:30 PM   #22 (permalink)
bobj3's Avatar
Hi Joe
Here are some snapshots of the Drum Sander plus a snapshot of the Jasper cir.jig my son drill out the center hole so I put in a plastic plug in with a 3/4" I.D. to use the brass guide, that just drops in the jig, with the plastic insert in place no need to bolt the jig to the router now , it can also be used on the router table by using the brass guide system and no fence needed.
Just a note *** by using a bigger brass guide and a vac. pickup on the router the chips will be pulled out the bottom that should help cutting cir. on the router table.
Bj
Part Finder
Bob J.
bobj3 is online now
Old 11-24-2006, 06:17 PM   #23 (permalink)
Banned
Joe Lyddon's Avatar
Joe Lyddon will become famous soon enough
Bob,
Thank you very much... looks pretty good & simple.
Why do you need that circle jig for this project? For the dust collection hose?
Joe Lyddon is offline
Old 11-24-2006, 07:39 PM   #24 (permalink)
bobj3's Avatar
Hi Joe
Cir.Jig, no I just got lazzy someone ask how to make circles on the router table and I put it in this post and the 1st.time I told him it would be hard but with this jig it's easy with a bigger brass guide and a good vac. system off the base of the router in the table mount, Just lazzy on my part I guess that I didn't recall who it was for sure .
Vac port,just a hole saw will do that quick and easy.
Joe just a note**** I had 7 old computer desks around and now I have 6 that's what I used for the sanding drum table to start with.
Bj
Part Finder
Bob J.
bobj3 is online now
Old 11-28-2006, 07:32 PM   #25 (permalink)
Banned
Joe Lyddon's Avatar
Bob & All,
I'm looking for a motor for the 18" drum sander... 1/2 HP.
I found this on Harbor Frt... do you think it's junk? Will it last awhile?
http://www.harborfreight.com/cpi/cta...emnumber=92105
There is a Baldor on eBay... nice... but $114 + frt which I know would be good... at about twice the cost.
Decisions... decisions...
Any other good motors out there?
How is your sander working so far... happy with it?
Old 11-28-2006, 08:12 PM   #26 (permalink)
Location: Butte Montana which is 1/2 way between Purgatory and Heaven
First Name: Jiggs
angus is on a distinguished road
Just courious - How did planing with a router evolve into a drum sander?????
Angus
angus is offline
Old 11-28-2006, 08:36 PM   #27 (permalink)
bobj3's Avatar
Hi Joe
I used the Grizzly one below because it was a Enclosed type and it would be working in dust cabinet so to speak,the dust box is just about a 1 1/2 " from the motor,and I rate motors by the amps. they pull that tells me a lot about the motor.
I have a had good luck with Grizzly motors in the pass.
I'm not sure about HF motors I have not used one >.
* Type: Enclosed
* Size: 1/2 HP
* RPM: 1725
* AMPS @ 110V / 220V: 8.8 / 4.4
Full 1 Year Warranty!
http://www.grizzly.com/products/G2528
The sander is working great , I was going to fire up the joint and the planer and I said OK lets see what this thing can do , Works great for both jobs.
I need to spend more time with it to keep out the snipe out on the end when I come off of it, like most tools, time,time,time with the tool.
JOE just a note ,,, the kit will come with 2 pulleys both are 1/2" I.D. so you will need to get a 5/8" I.D. one for the motor you should get a 2" OD one.
Bj
Part Finder
Bob J.
bobj3 is online now
Old 11-28-2006, 08:39 PM   #28 (permalink)
bobj3's Avatar
Angus
Who knows LOL hahahahahahaha LOL it just did LOL
Bj
Angus
Part Finder
Bob J.
bobj3 is online now
Old 11-28-2006, 08:41 PM   #29 (permalink)
Banned
Joe Lyddon's Avatar
I was wondering about that too...
Old 11-28-2006, 09:22 PM   #30 (permalink)
First Name: Jiggs
Well Im sure glad that I'm not the only one who noticed this. It's kinda amazing that on a router forum we can argue about the use of a tack rag, have word games, wood turning thouhts and ideas, or other venues that have no relation to the use of a router, but cannot keep a subject related and or referring to a router keep within the cofines of the subject.
Im sure I'll be critized for this, but hey it's not the first time. I really feel that the Router Forum is straying from it's original consept - to bad, I personally thought it's conception was great, but I and others I've contacted feel we're straying, is it due to lack of support or interest? Look at the repeat postings 2-3 4 weeks after the original- is this because there is not enough postings to keep fresh thoughts or ideas.
Angus
angus is offline
LinkBacks (?)
LinkBack to this Thread: http://www.routerforums.com/portable-routing/2555-planing-router.html
Posted By For Type Date
Home made jig for flattening slabs - Woodwork Forums This thread Refback 12-14-2009 06:04 PM
Edge Jointing (and Planing?!) with a Router: 24 How-To Guides, Forum Threads and Videos - ToolCrib.com Blog This thread Refback 04-01-2009 10:17 AM
New Router my way reible General Routing 16 03-13-2010 05:25 PM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 10 10-24-2009 05:34 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 06:59 AM
