| | #1 |
| Registered User Supreme Forum King | Some time in the past I saw a small sub-base that was sort of horse shoe shaped the attached to a small trim router. The added height let you better see the dowel as you flush trimmed it. I was thinking that I would like to build one to do the plugs that are used to fill in the holes made by "kreg" jigs. Does anyone recall where I might have seen this or have any of you made one? I have the PC 7310 that I intend to use for the router. If no one comes up with plans I will design my own (I might anyway) so let me know if you would be interested in seeing what I came up with. Ed |
| | #2 |
| Registered User Sr. Member | Sounds like a good idea. Can't say I have seen it myself but would like to see the end result. Aaron
__________________ The speed of light travels faster than the speed of sound, that's why people appear intelligent until they open their mouth ... |
| | #3 | |
I see some changes that have to be made but I will save that for after I play around with what I have for a while. Rather then try to explain I shot a few pictures. They are attached. I was very pleased with the end result, it is dead flat with the surface and it might not even need sanding. The kreg plugs are to costly to play with just yet so I have done one yet. Ed Last edited by reible; 10-07-2004 at 05:05 PM. | |
| | #4 |
| The Router Guys Forum King | Looks like a cool way to use your trim router...good idea!
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. |
| Flush trim bit not flush | RuggerJoe | Router Bits - Types and Usage | 8 | 03-19-2008 01:57 PM |
| Flush trim bits | Hamlin | Router Bits - Types and Usage | 4 | 12-01-2007 02:51 PM |
| Flush Trim Bit? | cbsjoez1935 | Router Bits - Types and Usage | 5 | 07-28-2007 12:35 PM |
| Where to get a flush trim bit? | wanart | Router Bits - Types and Usage | 4 | 10-28-2006 09:39 AM |
| flush to recessed cut? | fletch9 | Starting Off | 6 | 09-10-2006 08:44 PM |
