| | #1 |
| Registered User Supreme Forum King | One of my additions for my Hitachi router was a dust collector. This is the first time I have ever had dust collection on any portable router. But...... No it is not a matter of it not working well, the dust and chips get cleaned away but the hose always seems to be in the way or catching as you move along. It is hard enough to make sure the cord is free without having a second "strap" attached to take care of. Now some of you must be already using this type set up, so what do you do with the hose? I was thinking about getting it up in the air some how but working outside a skyhook seems the only way. Maybe I should limit the use of it to certain projects... haven't tried to use the router with it on but not hooked up??? It comes off easy enough but at that point it would be easier to swap bases to one with out the pick-up. Perhaps I just need more time to adjust to working this way?? So lets here some thought on this. Ed
__________________ Sometimes you get, and sometimes you get got. Last edited by reible; 07-15-2006 at 01:43 AM. |
| | #2 |
| Registered User Forum Fanatic | Ed, does Hitachi make a dust collector, or is yours of your own design? steveo |
| | #3 |
| Forum Contributer Supreme Forum King | Hi Ed The vac. pickup hose on the portable router can be a pain, this is what I did to help with it. The boss had a old vac. and I took the small hose and used it on my router ,it's about 1 1/4" in dia. and about 4ft. long then made a apt. to use it on my 2 1/2" hose shop vac. It's works great because of the smaller size hose that I need to drag around with me over my shoulder. Here's a link to the vac.pickup on my router,the insert is about 1 1/2" deep to hold the hose end in. ( made with MDF stock) not glued in just a press fit. With that and a remote switch in my pocket for the shop vac. it's a great setup. http://www.routerforums.com/attachme...achmentid=2485 Ya I know the Lo-Jack plastic card box is a bit cheap on my part but I'm from the old school, reuse if you can if not make one and then at the last buy a new one. Bj ![]() |
| | #4 | |
Ed
__________________ Sometimes you get, and sometimes you get got. Last edited by reible; 07-15-2006 at 01:41 AM. | |
| | #5 |
| Retired Moderator Forum Geek | Ed I tried the dust Collection with my Bosch when i first got it and after using it on one project it was relished to the case that is in the way. If I had to do all of my routing indoors I would hook up a swing arm or slidding hanger above my table for the hose and cord on light weight Springs so i would have easy movement of the router. I would also use a large downdraft table the size of my work bench with 3 sides about 2 foot high to keep the dust from leaving the table. But since I am limited to shop space the outdoors, Open work area on or around my work bench will have to do.
__________________ Regards Randy PC Support Forums, Free on line virus Scan, The Parasite Fight, Subratam.org -> Kill Spyware Forums A.S.A.P. Proud member since 2004 ~ |
| | #6 |
| Forum Contributer Supreme Forum King | Hi Ed Just a note on remote controls. And the Reuse thing. Here's a snapshot or two of the one I made from a old auto alarm system that's quick and easy to make. It's true you can buy one from Grizzly and others but when you have the stuff you need why. Plus the auto remote switch is smaller and just right for my pocket. I did buy one for my 2 hp Grizzly Vac.system because I was not sure the one I made would take on the 2 HP motor but I was sure it would take on the shop vac. easy. Bj ![]() |
| | #7 |
| Senior Moderator Supreme Forum King | Ed, a simple boom on a stand with casters and a longer hose sounds like a solution. One home made sky hook deluxe. And for that dragging power cord? I use a portable IV hanger. This is just a 5' tall post mounted on casters with a "U" shaped top. This also works great for air lines, you just put the cord or line in the "U" shape and it keeps it up out of the way. While we are being inventive wouldn't it be great to mount the boom on the post and have it all in one? The base would need to be heavy for stability but it shouldn't be too difficult.
| | #8 | |
As for as remote controllers, if I would want to do that I would use X10, most of my house is already done that way and it is as easy as plugging in a modual and using one of the remotes I have. What I like better is to use a box that I got from Sears that you plug in to an outlet then plug the router in to the sensing outlet on the box and the shop vac in to one of the switch outlets. Then when you turn on the router the vac starts.... turn off the router the vac stops. Just works better for me. Ed
| | #9 | |
Ed
__________________ Sometimes you get, and sometimes you get got. Last edited by reible; 07-15-2006 at 01:40 AM. | |
| | #10 | |
I do have a portable vac that hangs on your shoulder... like the ones they use to clean up copy machines... I could go self contained but the bag is small so stopping all the time to empty it....... Hmmmmmmmm Ed
__________________ Sometimes you get, and sometimes you get got. Last edited by reible; 07-15-2006 at 01:39 AM. | |
| Portable router table | mialorena08 | Introductions | 4 | 06-09-2008 02:31 AM |
| Mixing Bosch 1617 Router fixed base with Craftsman professional router | sf_basilix | Starting Off | 5 | 01-21-2008 09:54 AM |
| Motorized Router Lift - Eagle Lake Style | johnwnixon | Table-mounted Routing | 10 | 09-13-2007 07:59 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest - VOTING STAGE!! | Mark | Contests Archive | 13 | 11-05-2006 03:23 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest!! | Mark | Contests Archive | 72 | 10-01-2006 01:02 PM |
