Go Back   Router Forums > Routers > Portable Routing
Portable Routing Discussion area on the Portable Router and its applications. Bob and Rick say, "If the piece is bigger than the router then chances are it should be routed with the portable router."
Thread Tools Display Modes
Old 10-06-2004, 02:06 PM   #1
rout-on
Dedicated Member
rout-on is on a distinguished road
Default How many passes..........
I am curious to know if someone has a reference table as to how many passes should be done when ,let's say for an example, a spiral or straight-cutting bit is used to make a desired slot.Of course this depends on the thickness of material and its density or type( Hardwood as opposed to softwoods).My owner's manual does tell me what speeds to use according to pliability of woods being cut,but not if it can be completed in 1 pass.Any ideas..................
rout-on is offline   Top - Reply with Quote
Old 10-06-2004, 03:16 PM   #2
Spacemanspiff
Sr. Member
Spacemanspiff is on a distinguished road
Well I have heard not to make a pass that is any deeper than half the diametre of the bit you are using. I use it as a general rule of thumb and it seems to work. However, it does worry me that if I chuck up a 12mm straight flute and try to take off 6mm in one pass that it is too much. In this case I only take off 3mm at most. So I guess what I am saying is 3mm cut maximum. (ALthough the last cut I make is a very light one to clean it up).
Hope this is not too confusing.
Aaron
The speed of light travels faster than the speed of sound, that's why people appear intelligent until they open their mouth ...
Spacemanspiff is offline   Top - Reply with Quote
Old 10-07-2004, 06:17 AM   #3
template tom
Forum King
Whilst I agree with Aaron.
The depth of cut will vary with the type of material being cut (hard or soft) and I suppose we should take into consideration the sharpness of the cutter. But always leave that Imm for the final cut as Aaron suggested.
Tom
Old 10-07-2004, 08:28 AM   #4
ejant
Router King
Supreme Forum King
ejant's Avatar
ejant will become famous soon enough
I have found if not sure start with shallow passes and get the feel for the material/bit and how they are reacting together. Then adjust accordingly.
ejant is offline   Top - Reply with Quote
Old 10-07-2004, 02:24 PM   #5
rout-on
Dedicated Member
Thanks,basically what I thought,but always appreciative from other input.
Old 10-16-2004, 10:42 PM   #6
Dewy
Forum Fanatic
Dewy's Avatar
Dewy is on a distinguished road
Although many will use different depths of cut, I find it's something you get used to depending on the material.
You would make a shallower cut in a hardwood than you would on a softwood.
I like to use a bit of waste wood to try a few cuts on before going to the workpiece.
That way I can get the feel of the wood first.
I spent all my working life in a toolroom mainly using a vertical mill which is like a huge overhead router.
When you are cutting 5% chrome steel you soon learn to get the feel of the material you are cutting or the cutters will overheat and break.
Dewy
support team at Paltalk voice chat program
Dewy is offline   Top - Reply with Quote
Old 10-25-2004, 02:34 AM   #7
Putzger
Member
Putzger's Avatar
Putzger is on a distinguished road
Send a message via AIM to Putzger
That's dead-on advise
As an example of it, I was cutting a 28" long slot through a piece of finished 3/4" particle board today (It's the adjustable pivot point slot for a band saw circle cutting jig).
The first plunge cut with a 1/4" spiral up-cut bit seemed to go rather quickly so I tentatively began a full-depth route. I went quite slowly, but it just didn't seem "quite right".
I changed over to making an 1/8th- deep pass and WOW! The bit bore across that material as if there were no tomorrow. So shallow cuts it was.
I think I was finished and cleaned up after making several passes in less time than it would have taken me to make a single dep pass. (And I'm sure the router bit liked the several-passes way of doing it better as well :-) )
So yeah, playing it by the feel of the material is the only realistic way to go. Some stuff just cuts faster and cleaner than other stuff -- but you aren't going to know 'til you get into it
Steve
www.apachetrail.com/ww/
Mesa, AZ
Putzger is offline   Top - Reply with Quote
Incra Ultra How-To (Box Joints + Other Stuff) Nickbee Show N' Tell 5 01-21-2008 09:14 AM
Fogelberg Passes On.... challagan Lobby 2 12-16-2007 09:34 PM
Router Table Ver1.0 (Lots-o-Pics) Nickbee Table-mounted Routing 15 12-06-2007 09:52 AM
