Go Back   Router Forums > Routers > Portable Routing
Rate This Thread - tambour grooves routing problem.
Thread Tools Display Modes
Old 07-20-2006, 12:10 AM   #1
glencross
Jr. Member
glencross is on a distinguished road
Default tambour grooves routing problem
my first 4 bread boxes with tambour doors went fine....now i am making another and have routed the one side ok but am having real problems with the other side's groove...despite anchoring down the side to my workbench with nails and also the template, the router seems to have a mind of it's own despite my attemting to keep the router tight against the template...have used 6 blanks so far!!! HELP!!!
glencross is offline   Top - Reply with Quote
Old 07-20-2006, 04:53 AM   #2
template tom
Forum King
Seems as if you might be feeding the router in the wrong direction
Tom
Old 07-20-2006, 07:16 AM   #3
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Any chance the bit was bent? Does it run smoothly with no load? Is the bit dull? A dull bit will not cut properly and you mentioned having made several of your ends with no problem. Is this a carbide bit? What type of wood are you working with? Has your guide bushing come loose?
Old 07-20-2006, 09:49 AM   #4
glencross
Jr. Member
carbide bit fine: guide secure:am routing correct direction i.e. left to right.will try another bit and report back....thanks for replies.
Old 07-20-2006, 09:50 AM   #5
glencross
Jr. Member
also, runs smoothly with no load...am using pine.
Old 07-21-2006, 12:43 AM   #6
awh
Member
awh is on a distinguished road
The direction you feed the router into the material in this situation isn't gong to matter, because one side of the flutes will be climb cutting no matter what direction you work the router.
I suspect the bit you're using isn't as sharp as it could be or you have the router speed set too low. At low RPMs the router will tend to follow the direction of the grain, just as a dull bit will. A sharp router bit will cut with very little effort in any direction you push it.
When I make roll top desks I use a piece of plywood as the template that has a 1" slot cut in it, I simply clamp it to the work piece and using a router with a corresponding bushing so that the slot traps the router from wandering. Also, I use a downspiral bit, so that it leaves a nice clean edged groove, and I make 2 passes to get the required depth.
Happy Woodworking!
Tony
awh is offline   Top - Reply with Quote
Old 07-21-2006, 12:56 AM   #7
glencross
Jr. Member
thanks tony!
i am also soon starting on a roll top desk and your comments re the plywood slot etc sound very interesting so i will definitely be trying that!!! will change my bit tomorrow and see what happens!! thanks again. cheers
Freehand routing Visteonguy General Routing 34 08-25-2008 10:33 PM
Acrylic routing problem marc.brunet.gagne Introductions 1 05-08-2008 01:04 PM
Routing Template Verlin Garrett Jigs and Fixtures 5 02-06-2006 03:43 PM
routing accurately spaced grooves in boards for a house entryway system? paulcomi General Routing 5 10-03-2004 05:24 PM
Routing end grain Pop_pop1 Table-mounted Routing 8 09-22-2004 12:24 PM
