Help
Go Back   Router Forums > Routers > Portable Routing
laminate trimmer
This is a discussion on laminate trimmer within the Portable Routing forums, part of the Routers category; Im about to lay new counter top on bath vanity and want to know how ...
Old 08-07-2006, 07:48 PM   #1 (permalink)
Jen Jen is on a distinguished road
Default laminate trimmer
Report Post Report This Post!
Im about to lay new counter top on bath vanity and want to know how do I rout up to a wall on the end of vanity? My router like others prevent to get bit to tne edge of the vanity where the wall meets.
Jen Jen is offline
Old 08-07-2006, 08:21 PM   #2 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
Hi Jen Jen
Most lamminte trim routers come with a roller guide, it's made just for what you need to do.
The norm, the roller is on the out side of the router and against the wall when you use it.
You set the laminate on wood right next to the wall and then run the router down the wall with the roller running on the wall and cut the laminate to fit the wall.
Once you have it trimed remove the wood under the laminate and push it back to the wall for a test fit, if it fits right put down the glue , wait till the glue is dry then put your sticks down to hold the laminate up off the top, then start removing the sticks from the center out once you have removed all of the sticks grab the roller and remove the air from under the laminate.(roll it out from the center out) .
Besure to clamp the laminate b/4 you start the trim, so it can't move on the couter top.(block of wood under the laminate and then clamp it to the vanity top.)
Take care with the clamp it will crack or snap the laminate if it's not clamped right (flat) .
Just a NOTE*** if laminate goes next to a wall ,left or right side besure to cut the front side of the laminate b/4 you glue it down.
Just push it back into place clamp it down(with a wood block) and cut about a 2 1/2" or 3" long cut on the front end of the laminate/couter top, once it's glued down this part of the top you can't get the router into because of the wall will stop it.
Then you can use a file to clean it up a bit after you have it glued down.
Hope this helps
Bj
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
Many Router Tips from RWS
http://www.routerworkshop.com/router_tip_glossary.html
http://www.routerforums.com/email-ro...-members-only/
Router Tables ,Ready to use
http://www.rt1000.com/
http://rt1000.com/_wsn/page2.html
Bob J.
Old 08-07-2006, 10:59 PM   #3 (permalink)
Thank You for the lesson Bob
Jen Jen is offline
Old 08-07-2006, 11:12 PM   #4 (permalink)
bobj3's Avatar
You're Welcome Jen Jen
Bj
Post a snapshot when you get done I'm sure others would like to see it..I know I would also
Part Finder
Bob J.
Old 08-08-2006, 12:20 PM   #5 (permalink)
bobj3's Avatar
Hi Jen Jen
Here's a snapshot or two to show you how to set the router up.
Note the roller on the out side of the router base it controls the cut.
Bj
Part Finder
Bob J.
Thoughts on the RIDGID Laminate Trimmer.. the2js97 Starting Off 3 05-11-2008 06:51 PM
Laminate Trimmer Dave_Willemain General Routing 0 05-10-2008 11:01 PM
laminate counter top lyoncub Starting Off 2 01-10-2008 10:57 PM
