making box joints with a trimmer? - Router Forums
post #1 of 19 (permalink) Old 07-02-2012, 03:18 AM Thread Starter
First Name: Steve
hi
i'm new here. i just have access to a trimmer not a full router.
Is it possible to make box joints with it?
The wood pieces i am working in are small, about 50 by 20 by 200mm .
Thanks a lot .!
bigguy88 is offline
post #2 of 19 (permalink) Old 07-02-2012, 03:48 AM
Honored Member
harrysin's Avatar
First Name: Harry
Originally Posted by bigguy88 View Post
hi
Thanks a lot .!
If I understand you Steve the wood is 20mm thick, rather thick for a trim router, you would have to feed very slow and risk burn marks. You would of course have the trim router mounted under a table unless you are capable of making a suitable jig for use with a straight bearing bit. What is it that you're making, perhaps there is a more suitable joint. These shots show the basic type jigs that are used for routing box joints. By the way, welcome to the forum.
Harry
harrysin is online now
post #3 of 19 (permalink) Old 07-02-2012, 06:31 AM
G'day Steve.
Welcome to the forum.
Sydney, Australia
jw2170 is offline
post #4 of 19 (permalink) Old 07-02-2012, 09:13 AM Thread Starter
First Name: Steve
thank you!
Sorry, i meant to say it is 10mm thick and not 20mm.
the trimmer i got is a Maktec MT370. There is 4 small screws at the base. I guess I could build a small router table for it and then a jig .
On hindsight, I should have maybe pay twice the price and get a Hitachi router instead.
bigguy88 is offline
post #5 of 19 (permalink) Old 07-02-2012, 09:23 AM
Honored Member
harrysin's Avatar
First Name: Harry
The Maktec is made by MAKITA and is a first class product. Table mounted I don't see a problem using 10mm material. Post a couple of photographs when your project is finished, including any errors, and we all make those Steve!
Harry
post #6 of 19 (permalink) Old 07-02-2012, 09:29 AM
Bradleytavares's Avatar
First Name: Bradley
Been using a trim router as a dedicated router for dovetails as well as box joints. Seems to work well. Have a PC jig and real happy with it all
Bradleytavares is offline
post #7 of 19 (permalink) Old 07-02-2012, 09:49 AM Thread Starter
First Name: Steve
Do you use a router table for doing the dovetails?
my trimmer is using 1/4" shanks. I read I should not use too big a router bit as this trimmer has no variable speed control. Could I still use a dovetail bit?
bigguy88 is offline
post #8 of 19 (permalink) Old 07-02-2012, 09:51 AM
thank you!
HI Steve - That appears to be a quality router. The only issue that may come up with your application is that it appears to be a fixed speed, 35,000 rpm machine. You may need to develop some techniques to cut down on tearout. You may also experience some burning but that should be hidden by the joint and of no real consequence.
John Schaben
jschaben is offline
post #9 of 19 (permalink) Old 07-02-2012, 10:00 AM
First Name: Bradley
mine is used in a PC jig, no router table for eather joint. Burns are hidden by the joint so they don't show. Tear out is stopped by precutting the ends. Haven't had any issues with the speed. Enjoy your time in the shop.
post #10 of 19 (permalink) Old 07-02-2012, 10:12 AM
fep
Country: South Africa
First Name: fred
table mount the router
Steve I would defintely fix the router to a router plate, it is just so much easier and safer.
fep is offline
Human Verification
How to Make a Simple Clock Using Box Joints learnexperience Tools and Woodworking 2 08-15-2011 09:21 AM
Cutting box joints on a piece longer than 1 3/4" Edy Jigs and Fixtures 16 09-17-2009 11:19 AM
Scott Slinking Tools and Woodworking 3 01-21-2009 02:20 PM
