| | #11 |
| Registered User Supreme Forum King | I wonder if it's possible to take springs from pens and wind them onto the brush wire.. I'll have to look into that..
__________________ Mike - Retired FoMoCo Tradesman My Gallery @ http://www.routerforums.com/axlmyks-stuff/ |
| | #12 |
| Forum Contributer Supreme Forum King | HI Mike Maybe but I don't think so ,they are to strong/stiff ,they must be just right not to much pressure but just touch, almost float, I make alot of my own springs on the lathe but I don't have that wire size. But I'm sure you can find some springs at the hardware store (or from a motor bush sets) or motor repair shop that would work if the need comes up.
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 02-21-2007 at 09:55 AM. |
| | #13 | |
| Retired Moderator Supreme Forum King | Quote:
corey | |
| | #14 | |
| Registered User Forum Fanatic Join Date: Jan 2007 Location: Midwest,Wisconsin First Name: Gary Posts: 153 ![]() | Quote:
Gary Last edited by seawolf21; 02-21-2007 at 10:55 AM. Reason: Add images | |
| | #15 |
| Retired Moderator Supreme Forum King | Looks like it used to be a plunger as well. I have a Craftsman base for mine that works pretty good and have used it to do carving work on signs, trash bins, vegtable bins and the like. Corey
| | #16 | |
| Registered User Jr. Member | Quote:
Yes, I like the Homier trim router. I have used it to make 5 signs. Two were about 18" x 24". Yes I use str. bites on all the signs. Have tried mill end bits also but the 3/8" double flute straight bit I have seems to cut better without a lot of wood smoke/burn. No I have not tried a straight edge but after I made the two large signs I realized I could have gotten a sharper outer edge if I had of used some kind of edge guide. I plan to try this on a future sign. BTW Harbour Freight sells a 1/4" trim router that is identical to the Homier. You can usually find it on sell for $19.99 at their stores...watch for their flyers...which is about the same as the Homier with shipping. If you can catch it on sell for $19.99 and get one of their coupons like I did recently, I got it for about $16 at the store. Now I have two 1/4" trim routers. I recently used one of them with a small roundover bit on several pieces of wood and it was a pleasure to use... much easier than a normal size router for job I was doing.
__________________ You can't work without tools. | |
| FREE Freud DVD | bobj3 | Lobby | 3 | 06-15-2008 05:06 PM |
| Free Project Plans Forum is back! | Mark | Lobby | 0 | 11-27-2005 10:47 PM |
