The Network:
 Recommended Stores:
RouterForums.com - Your Online Router and WoodWorking Community
Login
RouterForums.com Search:
    Advanced Search
FAQ
Go Back   Router Forums > Routers > Portable Routing
Reload this Page Jointing with hand router
Portable Routing Discuss Jointing with hand router in the Routers forums; Thank you Del As I said in my reply to BJ, I live in Poland and the $40 will become ...
New Reply | Quick Reply
Thread Tools Search this Thread Display Modes
Old 01-01-2007, 10:19 AM   #11
simplenik
Forum Geek
User Info
Trader Rating: (0)
Gallery: View
simplenik is on a distinguished road
Send Private Message | View Profile
Thank you Del
As I said in my reply to BJ, I live in Poland and the $40 will become at least $80 or more considering the shipping (if they ship), customs tax and 22% VAT.
I'm an amateur and I'm trying to save money on things that I can make myself or come around with an alternate methods. So even the $40 are expensive for me.
Here is a jig that I intend to make, it was invented long time ago by a person that passed away 5 years ago (at the age of 86) and it's for use on the router table with flush trim bit.
niki
Click to Enlarge
simplenik is offline   Top | Reply with Quote |
Old 01-01-2007, 05:08 PM   #12
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
User Info
Trader Rating: (1)
Gallery: View
Country: USA
niki
I see you like to make your own jigs like I do and I know you said you can't get Amazon to ship to you but maybe you can have someone buy the items (books) below and send them to you, I do highly Recommend the BOOKS below .
Woodworking with the Router
http://www.amazon.com/Woodworking-R...ie=UTF8&s=books
Router Magic
http://www.amazon.com/Router-magic-...ie=UTF8&s=books
They both have many jigs in them and cover routers from A to Z...
Bj
Workshop Projects
Router Tables plans FREE, plus more
http://www.absolutelyfreeplans.com/...op_projects.htm
RW Router Tip Archive
www.routerworkshop.com/router_tip_glossary.html
bobj3 is offline   Top | Reply with Quote |
Old 01-02-2007, 10:52 AM   #13
simplenik
Forum Geek
User Info
Trader Rating: (0)
Gallery: View
Thank you BJ
Interestingly, Amazon does ship books to all over the world, but only books.
I bought Bill Hylton's book some 10 years ago from Amazon and it's my "Bible"
At the same time I bought also Roy Sutton's "Jig making for the router", he is covering all the basic jigs including stairs building jig and all of them are the "mother" of simplicity.
niki
Old 04-01-2008, 06:36 PM   #14
Falegname
Member
User Info
Trader Rating: (0)
Gallery: View
Falegname is on a distinguished road
I tried jointing with a router and a straight edge jig. The first board worked OK, but the second was a disaster. The router started ripping out chunks of wood and splintering the edge of the board. Here are the particulars:
Wood: poplar 7/8" thick
Bit: carbide, brand new 1/2 "straight bit, 1/2" shank, 1 1/2" cutting depth
Speed: 23,000 rpm
Depth of cut: 1/16"
Turns out I was going against the grain. Is that a no-no? Was I trying to move the router too fast? Would someone please try to tell me the error of my ways? Thanks.
I'd like to include pictures but don't know how to do it. Would some help me there? Again, thanks.
Regards, James
Falegname is offline   Top | Reply with Quote |
Old 04-01-2008, 07:01 PM   #15
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
User Info
Trader Rating: (1)
Gallery: View
Country: USA
Hi Falegname
You should be fine, sometimes you need to go against the grain but it's not the best way the norm , I would suggest you to check the bit for damage..
Or maybe just sand off the 1/16" with your belt sander..
You can make a quick jig that holds the belt sander on it's side and a fence just like doing it on the router table or jointer...
Here's link to show you how to UPLOAD some pictures
http://www.routerforums.com/howattachment.php
http://www.routerforums.com/help.php
Speed: 23,000 rpm
Depth of cut: 1/16"
Workshop Projects
Old 04-01-2008, 07:13 PM   #16
Falegname
Member
User Info
Trader Rating: (0)
Gallery: View
Post Jointing with a router
Thanks BJ. Here is the picture.
Regards, James
Old 04-01-2008, 07:20 PM   #17
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
User Info
Trader Rating: (1)
Gallery: View
Country: USA
You'er Welocome James
Looks like it ,,the bit started to bounce around a bit then it dug it , you may want to recheck the jointer fence to see it's set right or moved just a bit after the 1st. pass...
Maybe take a lighter cut,,,,1/64" then try it one more time..then make a pass or two to get it just right.
Workshop Projects
Old 04-01-2008, 07:31 PM   #18
Falegname
Member
User Info
Trader Rating: (0)
Gallery: View
This wasn't done on a jointer. It's a jig I found in Wood magazine. A straight edge fastened to a base; set back the distance from the edge of the router base to the edge of the bit. The workpiece is then clamped below the base. I left 1/16" exposed. The first one I did was fine. The bit was used twice: once to joint the edge of the plywood base and then to joint the first workpiece. Would a new carbide bit go bad that quickly? However I remember an old adage: "A good workman never blames his tools"
Regards, James
Old 04-01-2008, 08:03 PM   #19
Falegname
Member
User Info
Trader Rating: (0)
Gallery: View
Default Jointing with a router
Bob,
I went back and checked the bit, checked straight edge, and tried again on a piece of scrap; again against the grain with a 1/16" exposure. Only this time a lot more slowly. No problem this time. It looks like I was feeding way too fast. Ah, well. We live and learn; and make firewood as someone said. Thanks for your help and being a sounding board.
Regards, James
Old 04-01-2008, 08:31 PM   #20
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
User Info
Trader Rating: (1)
Gallery: View
Country: USA
Hi James
That's what I tough it was done with routers table can do a great job.
A new blade can go bad right off the bat,,,the cutting edge is very,very small.
Hardwoods can dull them in a heart beat..
I know most say crank up the speed on small bits but I always keep the speed down, heat kills bits and speed = heat...the router will tell you if you are going to fast or to slow, it has a voice...
" "A good workman never blames his tools"" I bame the tool all the time , router bits are not all made the same,,, some good one and some bad ones, from the same Mfg. I call them made on a Fri.at 5:00 o'clock bits...
Workshop Projects
Search this Thread:
Advanced Search
router table jointing dtaylor15 Table-mounted Routing 3 02-22-2006 09:21 AM
Router Jointing Drick General Routing 1 12-19-2005 09:21 PM
jointing jimcrjfo Table-mounted Routing 6 11-23-2004 10:35 AM
Jointing alternative? ktritz Table-mounted Routing 15 11-08-2004 03:22 PM
My finger jointing jig Spacemanspiff Jigs and Fixtures 11 10-31-2004 02:05 PM
Powered by: vBulletin Version 3.0.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd. - Copyright 2007 RouterForums.com - Search Engine Optimization by vBSEO 3.0.0
Professional Web Hosting provided by: RosenMill Technologies
