| | #21 |
| Registered User Member | Thanks Bob. What speed would you recommend under the conditions described in my first post? As a router neophyte I'm open to all the tips and suggestions I can get. Understand the "Fri. at 5:00 bits". Good description. Do you find MLCS and Grizzley bits acceptable? I'm gradually adding to my inventory.
__________________ Regards, James |
| | #22 |
| Forum Contributer Supreme Forum King | Hi James Speed,,, I use about 12,000 rpm or less the norm,, you need to think about how fast that it.. ![]() " MLCS and Grizzley bits acceptable " = Yes, they have two grades most are fine for most jobs but if I/you have a hard job I do use the higher end ones from MLCS and Grizzly.
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ Last edited by bobj3; 04-01-2008 at 09:57 PM. |
| Jointing long boards | Jtomwoods | Table-mounted Routing | 8 | 05-25-2008 09:05 PM |
| Bit for jointing question | dabeeler | Router Bits - Types and Usage | 11 | 11-13-2007 10:57 AM |
| Router Jointing | Drick | General Routing | 1 | 12-19-2005 09:21 PM |
| jointing | jimcrjfo | Table-mounted Routing | 6 | 11-23-2004 10:35 AM |
| Jointing alternative? | ktritz | Table-mounted Routing | 15 | 11-08-2004 03:22 PM |
