| | #1 |
| Registered User New Member | My first of many questions is. Can a 17mm wide dado be cut on veneered chipboard without the veneer chipping?. The boards are 600mm wide and the dado is to support the shelfs of a builtin cabinet. Any suggestions on technique would be appreciated. Cheers, Terry. |
| | #2 |
| Registered User Forum King | Terry. One method I've used with success is to score the limits of the cut with a sharp craft knife before routing to prevent splintering of the surface. This is a newbie's solution and our more experienced members might have better ideas.
__________________ Pete I've cut it twice and it's still too short! But only at one end. |
| | #3 |
| Registered User New Member | Thanks nzgeordie, I will try ur tip. Once I cut the boards to required size I will experiment with some offcutts and see what happens. |
| | #4 | |
| Forum Contributer Supreme Forum King | Hi Terry Geordie way works well but if you don't trust the cut you can do, you can do it one more way,with a veneer clamp boards(s) PLUS Great bit to use on veneered plywood, also the Down Spiral bit works well It puts presser down on the veneerer or the top part of the plywood ,holding it down so to speak. Compression Up/Down Spiral Router Bit This 2 flute solid carbide bit is needed to get clean, chip-free and splinter-free cuts in composite sheet goods such as Melamine or 2-sided Formica/Laminates and veneered plywood. The Up-shear/Down-shear design of the bit cuts toward the center of the sheet from both sides at once, saving time and eliminating waste. http://www.mlcswoodworking.com/shops.../bt_solid.html ========== Quote:
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ Last edited by bobj3; 12-26-2007 at 07:22 PM. | |
| Router Table Dado Jig | RoyBullets | Jigs and Fixtures | 11 | 06-16-2008 08:41 PM |
| Dado Jig for Plunge Router | bobj3 | Jigs and Fixtures | 19 | 10-30-2006 11:57 PM |
| FREUD Dado Sets | sawstop | Tools and Woodworking | 4 | 10-30-2006 03:57 PM |
| Router Adjustable Dado Jig | Barry_White | Jigs and Fixtures | 4 | 02-07-2005 01:17 AM |
| starting dado | Jens Jensen | Table-mounted Routing | 8 | 10-06-2004 09:55 AM |
