Go Back   Router Forums > Routers > Portable Routing
Portable Routing Discussion area on the Portable Router and its applications. Bob and Rick say, "If the piece is bigger than the router then chances are it should be routed with the portable router."
Thread Tools Display Modes
Old 11-02-2004, 11:19 PM   #1
Bluegillman
Jr. Member
Bluegillman is on a distinguished road
Default Three colors of dovetails
How did they do that? I have seen someone else's work that shows their dovetails that has three kinds of wood on a drawer, the face is oak, the sides is ash and in between them two is walnut about 1/16" to 1/8".
Bluegillman is offline   Top - Reply with Quote
Old 11-03-2004, 02:30 AM   #2
Kevin
Forum Administrator
Forum Fanatic
Kevin's Avatar
Kevin is on a distinguished road
I think the easest way to accomplish that would be to glue the three tyeps of wood together. Then cut the dovetails out of that pice of wood. But then again i can't exactly picture in my head what you are talking about :| Sorry
Kevin is offline   Top - Reply with Quote
Old 11-03-2004, 07:32 AM   #3
ejant
Router King
Supreme Forum King
ejant's Avatar
ejant will become famous soon enough
I think you are referring to a double dovetail joint. This is done with two different size dovetail bits.
ejant is offline   Top - Reply with Quote
Old 11-03-2004, 05:54 PM   #4
template tom
Forum King
As suggested two cutters are required first cut with the larger cutter then fill in the shape with the contrasting colour then when the glue has dried route with the smallet cutter to complete the joint. Looks good but an extra cut is required. Leigh Dove tail Jig
Tom
Old 11-03-2004, 09:30 PM   #5
Bluegillman
Jr. Member
Tom
It only can be "made" with Leigh tooling? That sounds like to me that I would normally just make the dovetail with two kinds of wood then cut one 1/8th away from ends and then recut it with a smaller one and mate it with the other side...I think I got the picture...
Old 11-04-2004, 07:55 AM   #6
ejant
Router King
Supreme Forum King
ejant's Avatar
There are othe jigs that can make double dovetails and even double double dovetails. Like the Incra jigs.
Old 12-07-2004, 08:54 AM   #7
ssgt
ssgt is on a distinguished road
Default Three Colours of Dovetails
This type of joint is a trade mark of the Incra dovetailing Jig. With the incra it is possible to cut what they call the double, double double, corner post and or the eagle. In fact it is possible to have 5 species of timber coming together in one corner ( one species for the side, one for the front, two for each of the fillets and one for the corner post). It is a very simple joint to cut using the Incra system, a look at incra,s web site will give you a good understanding. It is also possible to cut the double dovetail on the Leigh jig and also on the Woodrat. So far I have managed the double and the double double on my Woodrat. Using the Incra you cut the sockets and pins in the normal way, then cut a series of sliding dovetail keyways on a piece of 30 mm thick timber the same width as the drawer sides. Then slice a 3mm segment of this peice, glue it onto the original board were the sockets were cut. Once the glue is dry recut the sockets using the same cutter and bobs your uncle you have the double dovetail joint.
ssgt is offline   Top - Reply with Quote
Old 12-13-2004, 03:25 PM   #8
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
The Leigh dovetail jig can be used to do the 3 color dovetail, the side is cut with a different color wood, glue together the the pins to fit is another color. They are assembled with glue, and when dry the side is cut away from the pin board. It is then routed with a smaller bit, and a third board is cut with pins to fit the now smaller dovetail.
Hope this helps, Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Old 12-14-2004, 09:41 PM   #9
Bluegillman
Jr. Member
Sounds like any dovetail jig would do as long there is two size dovetail bits. I would like to try it one day.
Dovetails - more or less - opinion Donzoid General Routing 4 11-27-2007 02:02 PM
Rebated Dovetails garryjc Jigs and Fixtures 3 10-15-2007 03:24 PM
Sliding dovetails for cabinet constuction? Drugstore Cowboy Tools and Woodworking 18 07-08-2007 05:14 PM
through vs blind dovetails zxxer12 General Routing 4 03-02-2005 01:36 PM
Sliding Dovetails scrollwolf Table-mounted Routing 2 09-12-2004 10:59 PM
