Go Back   Router Forums > Routers > Portable Routing
Portable Routing Discussion area on the Portable Router and its applications. Bob and Rick say, "If the piece is bigger than the router then chances are it should be routed with the portable router."
Thread Tools Display Modes
Old 11-29-2007, 05:21 PM   #21
Rustic04
Rustic04 is on a distinguished road
Default Routed Bowls--A beginner's story.
All, very good reads on this subject. As a relative beginner, I have been wanting to try this bowl techique since the article came out in Woodsmith Issue 170. However, I have just recently attempted it and found it quite easy, even for this novice. Although I purchased a little bit of stock to try this out, it is great for using up scraps from other projects. I'm sure you guys would have much less of a learning curve than me, but here are a few pointers that I picked up by reading/re-reading the Woodsmith magazine article; playing/re-playing the on-line video; and, most of all, trial and error.
1. It was not initially obvious to me that Woodsmith was using a plexiglass router table insert to increase the footprint of the router so that the router base could be continually supported by both sides of the template. (I made a few unwanted gouges on the inside of the bowl on my first attempt before using the wider plate.
2. I found that using a router mat on my work bench worked much easier than attempting to hold the stock in a vice/clamp. This allowed me to easily re-orient the piece as needed during the routing.
3. I did not spend enough time "dressing up" the inside rim of my first MDF template. The template's oval cut on the scroll saw still had minor blade cut irregularities which, of course, translated into copied irregularities at those specific points in the bowl all the way down the inside of the piece. Thus, much more time was spent sanding out the inside of the bowl's hardwood instead of correcting this problem initially by sanding out the templates much softer surface.
4. I have a Skill router that comes with both a fixed base and a plunge base. I also used the recommended collet extension (which I think was 3 inches). I found that when using the fixed base without the collet extension, I could not adequately get low enough to align the top bit bearing against the 3/4" thick template when making the first few routing passes. Additionally, when using the plunge base with the collet extension, I could not get the bit high enough to take the recommended 3/16" (max) deep passes. It was initially just trying to gouge out too much at a time. So, my solution was to use another 3/4" MDF template (one of my first-try templates and let it "float" on top of the real template that was attached to my stock. The floating template doesn't even have to be the same size because I used it only for the additional thickness it provided. This extra floating template gave me more room above the stock to make my initial passes in the center of the stock before removing the extra template and then working slowly toward the sides of the bowl where the top bearing properly aligned with the attache template. Results: much smoother inside surface the first time. (make sense?)
Ok, you are all probably laughing at how green I am with this stuff, but I am really having fun. I would appreciate any feedback on how to do it different than I am.
Rustic04
Rustic04 is offline   Top - Reply with Quote
Old 11-29-2007, 05:33 PM   #22
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Rustic04
You may also want to check out the links below
http://www.youtube.com/watch?v=9EZgb...eature=related
http://www.routerforums.com/guide-bu...te-guides.html
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 11-29-2007, 08:41 PM   #23
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
Joe Lyddon is on a distinguished road
Rustic04
W e l c o m e !
I'm glad you had fun making the bowls... and thank you for your constructive notes!
Yep, those templates should be as perfect as you can get them... otherwise, it makes for more work or shoddy results.
Joe Lyddon is offline   Top - Reply with Quote
Old 12-01-2007, 06:00 AM   #24
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
Rustic04 (that does sound impersonal), as a relative newcomer to routing you should be made aware of the fact that there are different ways to use the router, some safer than others, some more accurate than others and some are both. For a method different to the one you have used, take a look at this link to a deep routed box that I did a photo-shoot on some time ago.
http://www.routerforums.com/40472-post1.html
Harry
harrysin is offline   Top - Reply with Quote
Old 12-01-2007, 02:45 PM   #25
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
Rustic04,
I was surprised to see the Woodsmith Link still functional!
http://www.woodsmith.com/issues/170/.../routed-bowls/
Enjoy...
