| | #1 |
| Registered User Forum Geek | I have a couple of home-made trammels that I use for routing arc's in various projects, but now I want to route a circle into a piece of 1/2" ply to mount my PC690 router in to. (2 pieces of 1/2" ply will be glued together). The trammels that I have appear to me to be too large to route a circle the diameter of the PC690 base. Any suggestions? |
| | #2 |
| Registered User New Member | You could route a circle Larger than the 690 base plate, in some scrap material. Make the circle large enough so the 690 base will fit in the center of the large circle. Remember to allow for the diameter of the bit. Then you will be able to use the large circle as a template to route your two 1/2" plywood pieces. They could be cut together, by temporary nails or double back tape. Good luck. Richard wey |
| | #3 |
| Banned Supreme Forum King | ... and that's the Wey to do it!! ![]() |
| | #4 | |
| Registered User Forum Geek | Quote:
Thanks for the suggestion. I'm trying to picture this. If I route a larger diameter circle (than the PC690 base) for a template, then I need to get another bit of some sort -- all I have now is a flush trim bit -- in order to get the diameter of the circle in the ply back to just large enough for the 690 base to fit into. Thanks. Last edited by NewMontanaWorkshop; 09-13-2004 at 04:38 PM. | |
| | #5 |
| Registered User | For circles smaller than a trammel will allow, best to make a custom subbase with a centre pin around which you can rotate the router. This pin goes off to one side of the cutter obviously, with the cutter projecting down through a slot. The nicest version of this can be slid along the standard subbase, and locked off in any position, providing an adjustible radius. For this you need to cut T-slots on the custom base, to accept bolts which go up through the mounting holes in the router base. Most router jig books have plans of such things. To use the fixture to cut a circle, you would drilla hole in the centre of the circle-to-be, pop the centre pin into it, then route out the circle. It helps to hold the workpiece down with double sided carpet tape. That way, the central offcut doesn't go ballistic as you finish the cut. Have fun Martyn (spelling of centre - UK style BTW) |
| | #6 |
| Marine Engineer Forum King | If I understand what you want to do, an easy way to do this would be to make a small router compass. The smallest one I use for inside cuts is a piece of 1x6 poplar with a 1" hole for a template guide. Then mark off your radius on the compass and drill a tight hole for your nail. On small inside cuts, where the piece is going to be pretty much covered up by the router the whole time, I like to double stick tape the parts to my cutting board, so that the center piece won't bounce around when cut free. I like using the thick boards for compasses because they don't flex, they don't wobble on the pivot hole after a couple of uses, and because some of my template guides are kinda long. The only other way I could think of doing it would be to use your existing plate as a template, but unless you had a spare plate that can use guide bushings, that might be more work than necessary. For making small outside cuts, I have a base plate for my router table that I have drilled as a compass, and it works pretty well for small circles if you rough cut the circle out on the bandsaw first. (good for plaques, toy parts, etc.) Hope these ideas help,
| | #7 |
| Registered User Forum Geek | Thanks much for the tips, will be giving the ideas a run this weekend and see how it works out. Thanks agian. |
| | #8 |
| Registered User New Member | try the circular router jig made by jensen.. ,, varies in sizes from 1' to about 8 ' i use one in my 690 and have good luck in makin small circles for wheels etc. |
| | #9 |
| Registered User Forum Geek | Guess I wasn't considering all the options when I first posted this question, after a few replies and a bit of shop time -- the solution was painfully obvious. Used the trammel to route the larger diameter circle in 1/2" MDF, the rest was easy. Thanks for the replies. |
| | #10 |
| Registered User Forum Geek | This is what I ended up with. Used the trammel to cut a template, then used the template to route the 690 baseplate size into some plexiglass. Last edited by NewMontanaWorkshop; 10-03-2004 at 11:23 PM. |
| A small shop "addition" | Hamlin | Hamlin's gallery | 2 | 03-28-2008 07:07 PM |
| Small diameter circles. | NewMontanaWorkshop | Jigs and Fixtures | 26 | 12-17-2007 12:04 PM |
| Gifkins small cutter diameter | S Bolton | Jigs and Fixtures | 17 | 11-29-2007 01:05 PM |
| small pieces | fishlore | Table-mounted Routing | 58 | 11-21-2007 08:23 PM |
| routing small pieces | zxxer12 | General Routing | 9 | 03-21-2005 04:40 PM |
