| Portable Routing Discuss Bosch COLT experience? in the Routers forums; No problem. I just cut the parts for my push block and I cut 3/4 inch dados easily with ... |
| New Reply | Quick Reply |
| | Thread Tools | Search this Thread | Display Modes |
| | #11 | ||
| Retired Moderator Supreme Forum King |
No problem. I just cut the parts for my push block and I cut 3/4 inch dados easily with it. I also take back my comments on the VS, I found it very useful with the bigger bits to dial into the proper speed and it did just fine. 3/4 inch red oak no problem. I really think I could do the bulk of my box cutting work with this router alone. It also shows me how much I like the Oak Park set up. Corey | ||
| | #12 | |||
| Forum Contributer Supreme Forum King |
Hi Corey That is what I'm going to do on Sat. drill the new holes in the new table to mount the Oak-Park Box joint jig(s) ... I think I said this b/4 but why use a 10lb. hammer to drive a tack in the board..when it only takes a small hammer to do the job... ![]() Quote:
__________________ Workshop Projects Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/...op_projects.htm RW Router Tip Archive www.routerworkshop.com/router_tip_glossary.html | |||
| | #13 | ||
Hey Corey You may want to have a peek at the snapshots I added to the new little table POST it shows the Oak-Park Box Joint Jigs in place and the push block.. ![]() see them on page #2 http://www.routerforums.com/jigs-fi...uter-table.html
| | #14 | ||
Looks good Bob..I commented in that thread. Corey | ||
| | #15 | ||
| Registered User Jr. Member |
Glad to hear the great reviews. I just ordered the installers kit from Amazon.com, variable speed model. | ||
| | #16 | |||
Hi Carl I'm sure you will like it you may want to read the link belowJust a add on item you can use with your new Colt... http://www.routerforums.com/jigs-fi...lunge-base.html http://www.routerforums.com/jigs-fi...uter-table.html =========== Quote:
__________________ Workshop Projects Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/...op_projects.htm RW Router Tip Archive www.routerworkshop.com/router_tip_glossary.html Last edited by bobj3 : 05-01-2008 at 06:00 PM. | |||
| | #17 | ||
Thanks Bob. Noted, and will read up tonight after work. Should be getting my new router tomorrow, next day delivery. | ||
| | #18 | ||
| Registered User Forum King |
The best 1 HP router with one exception. The three colts I had, all had the same problem. The router bit was not 100% perpendicular to the base from all direction. Even my little powerless Ridgid trimmer measures true from all sides.
__________________ router è ancora il mio nome | ||
| | #19 | ||
| Senior Moderator Supreme Forum King |
3 bad units in a row? Are you sure your bit wasn't bent?
__________________ Mike | ||
| | #20 | ||
Well, I had tried several different router bits and two centering pins with 3 super accurate squares. All are perfect in my other 4 routers. So, I would say either they had the same batch of routers at lowes with the same problem. Or no one is testing the same way that I do. Use a long router bit and test it from all 8 angles.
| Bosch router table using pc895 router under | routerron | Table-mounted Routing | 2 | 10-06-2006 11:50 AM |
| Hitachi M12V and Bosch 1619EVS routers | LBrandt | Table-mounted Routing | 3 | 06-03-2006 10:42 AM |
| Bosch 1617EVSPK or Bosch 1619EVS | LBrandt | Table-mounted Routing | 18 | 05-19-2006 03:35 PM |
| bosch colt palm router | stevie.c | General Routing | 2 | 09-01-2005 02:09 PM |
| My New Bosch Router Bosch 1617EVSPK Review | GoonMan | General Routing | 2 | 04-02-2005 05:25 PM |
All times are GMT -5. The time now is 04:47 PM. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 |
