Go Back   Router Forums > Routers > Portable Routing
Portable Routing Discussion area on the Portable Router and its applications. Bob and Rick say, "If the piece is bigger than the router then chances are it should be routed with the portable router."
Thread Tools Display Modes
Old 06-01-2007, 09:07 PM   #11
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
No problem. I just cut the parts for my push block and I cut 3/4 inch dados easily with it. I also take back my comments on the VS, I found it very useful with the bigger bits to dial into the proper speed and it did just fine. 3/4 inch red oak no problem. I really think I could do the bulk of my box cutting work with this router alone. It also shows me how much I like the Oak Park set up.
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 06-01-2007, 09:41 PM   #12
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Corey
That is what I'm going to do on Sat. drill the new holes in the new table to mount the Oak-Park Box joint jig(s) ... I think I said this b/4 but why use a 10lb. hammer to drive a tack in the board..when it only takes a small hammer to do the job...
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 06-02-2007, 12:15 AM   #13
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hey Corey
You may want to have a peek at the snapshots I added to the new little table POST it shows the Oak-Park Box Joint Jigs in place and the push block..
see them on page #2
http://www.routerforums.com/jigs-fix...ter-table.html
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 06-02-2007, 07:40 AM   #14
challagan
Supreme Forum King
challagan's Avatar
Looks good Bob..I commented in that thread.
Old 05-01-2008, 02:37 PM   #15
Carl762
Jr. Member
Carl762 is on a distinguished road
Glad to hear the great reviews. I just ordered the installers kit from Amazon.com, variable speed model.
Carl762 is offline   Top - Reply with Quote
Old 05-01-2008, 02:46 PM   #16
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Carl
I'm sure you will like it you may want to read the link below
Just a add on item you can use with your new Colt...
http://www.routerforums.com/jigs-fix...unge-base.html
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 05-01-2008, 04:00 PM   #17
Carl762
Jr. Member
Thanks Bob. Noted, and will read up tonight after work.
Should be getting my new router tomorrow, next day delivery.
Old 05-01-2008, 07:48 PM   #18
Router is still my name
Forum King
Router is still my name's Avatar
Router is still my name is on a distinguished road
The best 1 HP router with one exception.
The three colts I had, all had the same problem.
The router bit was not 100% perpendicular to the base from all direction.
Even my little powerless Ridgid trimmer measures true from all sides.
router è ancora il mio nome
Router is still my name is offline   Top - Reply with Quote
Old 05-02-2008, 02:57 PM   #19
Senior Moderator
Supreme Forum King
Mike has disabled reputation
3 bad units in a row? Are you sure your bit wasn't bent?
Old 05-02-2008, 03:32 PM   #20
Forum King
Well, I had tried several different router bits and two centering pins with 3 super accurate squares. All are perfect in my other 4 routers.
So, I would say either they had the same batch of routers at lowes with the same problem. Or no one is testing the same way that I do.
Use a long router bit and test it from all 8 angles.
Bosch Colt Hamlin General Routing 11 08-27-2008 12:17 AM
template guides for Bosch Colt RuggerJoe Guide Bushings and Templates 8 07-24-2008 12:17 AM
Bosch 1600 Router Experience cwo2tt General Routing 0 06-27-2008 01:37 AM
Bosch Colt Trim Router..... Does Yard Work challagan General Routing 7 07-27-2007 01:52 AM
bosch colt palm router stevie.c General Routing 2 09-01-2005 03:09 PM
