| | #11 |
| Retired Moderator Supreme Forum King | No problem. I just cut the parts for my push block and I cut 3/4 inch dados easily with it. I also take back my comments on the VS, I found it very useful with the bigger bits to dial into the proper speed and it did just fine. 3/4 inch red oak no problem. I really think I could do the bulk of my box cutting work with this router alone. It also shows me how much I like the Oak Park set up. Corey
| | #12 | |
| Forum Contributer Supreme Forum King | Hi Corey That is what I'm going to do on Sat. drill the new holes in the new table to mount the Oak-Park Box joint jig(s) ... I think I said this b/4 but why use a 10lb. hammer to drive a tack in the board..when it only takes a small hammer to do the job... ![]() Quote:
| | #13 |
| Forum Contributer Supreme Forum King | Hey Corey You may want to have a peek at the snapshots I added to the new little table POST it shows the Oak-Park Box Joint Jigs in place and the push block.. ![]() see them on page #2 http://www.routerforums.com/jigs-fix...ter-table.html
| | #14 |
| Retired Moderator Supreme Forum King | Looks good Bob..I commented in that thread. Corey
| | #15 |
| Registered User Jr. Member | Glad to hear the great reviews. I just ordered the installers kit from Amazon.com, variable speed model. |
| | #16 | |
| Forum Contributer Supreme Forum King | Hi Carl I'm sure you will like it you may want to read the link belowJust a add on item you can use with your new Colt... http://www.routerforums.com/jigs-fix...unge-base.html http://www.routerforums.com/jigs-fix...ter-table.html =========== Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 05-01-2008 at 07:00 PM. | |
| | #17 |
| Registered User Jr. Member | Thanks Bob. Noted, and will read up tonight after work. Should be getting my new router tomorrow, next day delivery. |
| | #18 |
| Registered User Forum King | The best 1 HP router with one exception. The three colts I had, all had the same problem. The router bit was not 100% perpendicular to the base from all direction. Even my little powerless Ridgid trimmer measures true from all sides.
__________________ router è ancora il mio nome |
| | #19 |
| Senior Moderator Supreme Forum King | 3 bad units in a row? Are you sure your bit wasn't bent?
| | #20 |
| Registered User Forum King | Well, I had tried several different router bits and two centering pins with 3 super accurate squares. All are perfect in my other 4 routers. So, I would say either they had the same batch of routers at lowes with the same problem. Or no one is testing the same way that I do. Use a long router bit and test it from all 8 angles.
| Bosch Colt | Hamlin | General Routing | 11 | 08-27-2008 12:17 AM |
| template guides for Bosch Colt | RuggerJoe | Guide Bushings and Templates | 8 | 07-24-2008 12:17 AM |
| Bosch 1600 Router Experience | cwo2tt | General Routing | 0 | 06-27-2008 01:37 AM |
| Bosch Colt Trim Router..... Does Yard Work | challagan | General Routing | 7 | 07-27-2007 01:52 AM |
| bosch colt palm router | stevie.c | General Routing | 2 | 09-01-2005 03:09 PM |
