| | #1 |
| Registered User Forum Fanatic | Hello, Doyle here. Need some help. I have a Porter Cable plunge router the plastic base plate of which will not center with the collet when the inlay guide bushing is in place. I would like to try my hand at an inlay, or two or three or more, just for practice before inlaying something in a project. The three screw holes in the plate are not large enough to allow centering the brass inlay gizmo with the inlay router bit. I have wiggled and jiggled, loosened and tightened every widget that I could put my fingers on, without success. The plastic base seems to center just fine. But with the guide bushing in place, centering with the inlay bit is all but impossible. Any idea will help. Thanks in advance and take care. Doyle |
| | #2 |
| Registered User Supreme Forum King Join Date: Nov 2006 Location: Fort Worth,Texas USA First Name: George Posts: 1,581 ![]() | Hi Doyle. Have you tried enlarging the screw holes on the base plate? This will give you a little wiggle room.
__________________ George For those who haven't already done so... PLEASE! PLEASE! Fill in your first name and location in your profile. I like to know who you are and where you are from. If you don't want me to know who you are, then I don't want to talk to you. |
| | #3 | |
| Registered User Forum Fanatic | Quote:
| | #4 | |
| Forum Contributer Supreme Forum King | Hi Doyle May I ask how far off is it. ? Most inlay kits come with a 1/8" bit and if it's more than a 1/8" off drilling the holes may not work...you are using the 1/8" bit and not a 1/4" one. I/8" off center is a big deal when it comes to base plates. ![]() B/4 you drill out the holes find a 1/4" dowel pin and chuck it up in the router and put in one of the brass template guides and hand turn the router shaft nut to check it,once it drilled out you can't put it back.. ![]() Bj ![]() Quote:
| Making your own sub base plate | Mike | Guide Bushings and Templates | 9 | 08-18-2008 10:43 PM |
| what guide bushing for craftsman router | vegeta88 | General Routing | 9 | 02-05-2008 09:49 PM |
| Mixing Bosch 1617 Router fixed base with Craftsman professional router | sf_basilix | Starting Off | 5 | 01-21-2008 09:54 AM |
| Guide bushing identification | Mike | Guide Bushings and Templates | 26 | 03-24-2007 10:57 PM |
| question about router plate | mwm500 | General Routing | 5 | 09-20-2006 06:58 PM |
