| | #1 |
| Retired Moderator Forum King | Hello everyone, I normally use my old Craftsman fixed base router to engrave wooden signs with my letter template kit. I got tired of tilt plunging the router into the wood so I decided to use my Bosch 1617evs plunge base router to do the engraving to see how easy it would be. When I finished I noticed what was happening to the letters. I started getting deep circle marks in the letters. I even plunged the bit just a hair deeper to level everything out and didn't push down on the handle while unlocking the plunge base to lift it up which I thought was the problem and I still got the same results. Then I plunged the bit just a 1/32nd of an inch deeper again and lifted the whole router out of the template kit and still the same results. My question is: Is it better to use the fixed base or plunge base? Maybe I should go back to my old way just to make engraved wooden signs. What do you think? The bit that I'm using is a 3/8" straight bit. The way that I did it before came out really nice after sanding everything out. But now, it's a whole other ball game. Hmmm.... ![]() Boricua Last edited by -Sam-; 12-05-2004 at 12:25 AM. |
| | #2 |
| Registered User Supreme Forum King | Are the marks from the bit at the location that you plunged it in? My first guess would be that the force of plunging the bit in is also flexing the lettering kit. I don't know how the lettering kit is made but some seem to have bars that hold the letters and if these are not supported then they would flex as you push down then as you start moving the pressure lets up and you are left with the marks. I would pick one of the letters and shim the kit near the letter and go another 1/32 deeper and see if it clears up. Also a bit that has a round nose wouldn't show the problem as much. The last issue is one that some people miss when picking bits for plunge operations. By looking at the marks it looks like you have a bit that is not designed for plunge cutting. You should get a bit designed to do plunge work, either a spiral or a plunging straight bit. The bit you are using does not have a cutting edge on the bottom and only marginally works for what you are doing. Ed |
| | #3 |
| Registered User Dedicated Member | I think Reible nailed it. You need a bit designed for plunging. Woodworkers Supply carries some, they have a carbide spur on the bottom just for that. Another is a bottoming bit used for routing out the bottom of dados with. Insure you also aren't pushing down with additional pressure in certain areas while routing. |
| | #4 |
| Retired Moderator Forum King | Reible, yes I believe so, that the marks from the bit is where I plunge the bit in. Your explanation of what is going wrong makes a lot of sense. Thanks guys, I will work on this when I get a chance and keep you updated. Attached is a picture of the lettering kit that I'm using. Later... Boricua Last edited by -Sam-; 12-05-2004 at 02:25 AM. |
| | #5 |
| Official Greeter Supreme Forum King Join Date: Sep 2004 Location: New Lebanon, Ohio "USA" First Name: Dave or "Doc" Posts: 4,690 ![]() | Borica, is this the same bit you used in the Craftsman or a different bit? I believe Ed is right. When you tilted in, you cut all the way across your letter. It looks like you are using an end mill bit for cutting metal.
__________________ Dave the "Doctor" In woodworking there is no scrap, only firewood. ![]() Please edit your profile with a name and location so we can better assist you and make for a friendlier forum. |
| | #6 | |
| Retired Moderator Forum King | Quote:
I attached a picture of the bit I used. Thanks again guys. Later...Boricua ![]() | |
| | #7 |
| Senior Moderator Supreme Forum King | All the sign making kits seem to be identical with the exception that the Craftsman kit is shorter than the ones marketed by Rockler and Lee Valley. I noticed that the plastic bushings on my Craftsman kit got a "trim" the first time I used it. I was considering using my 1617 with metal bushings and the plunge base so I would like to know if other than the swirl cut problem you were happy with the operation? I have only used round nosed cutters for the signs I have made, and the results are pretty good. Ed, you are right about the flexing problem with the bars, but when using round nosed bits the minor amount of flex doesnt seem to show. Mike |
| | #8 | |
It works very nice not having to tilt plunge that a router. You need to use a bigger base plate for the plunge base router though, since the baseplate for the 1617 plunge base is not wide enough. I have used round nose cutters before but some of the people that I make the signs for like the flat bottom instead of the round nose. Later...Boricua ![]() | |
| | #9 |
| Registered User Forum Fanatic | where are you guys getting these sign making kits? In the kits do they have very drawn out instructions and know how for dummies? I am VERY new to routing and am interested in doing these signs but is this more for experienced routers or is it just fine for rookies such as myself? shawn |
| | #10 |
| Senior Moderator Supreme Forum King | Boricua, the plastic guide bushings came with the Craftsman sign kit. They fit my Craftsman router, and yes, the bit trimmed the inside of the guide bushing a bit. Maybe too much side pressure from me? Someone else mentioned the plastic guide bushings being in the Lee Valley kit, and equally useful. This is why I was thinking of using my Bosch 1617 plunge with good collars. Shawn, Sears sells the kit for about $20. Rockler is about $40 and Lee Valley charges $55? Far as I can tell the Rockler and Lee Valley Tools sets are identical. The Craftsman kit is too, except the guide bars are shorter. Craftsman lets you align 8 pieces of letters, numbers, etc while the others hold 12. The instructions are clear. The jig is easy to use. If you live near a Rockler or Woodcraft store you could ask for a demo of the set up and use. PS It really helps to list a State/Province & Country in your profile. This way people can try to give specific answers to your location. Our forum members are world wide. Mike |
| My first sign project | AxlMyk | General Routing | 15 | Yesterday 08:23 PM |
| lettering into wooden signs- HOW? | moe | Project Plans and How To | 16 | 09-19-2008 10:49 PM |
| wooden sign suggestion | sawdustlisa | Introductions | 56 | 09-14-2007 08:23 PM |
| Wooden sign making | tigger | Introductions | 5 | 08-16-2007 06:31 PM |
