| | #11 | |
| Forum Contributer Supreme Forum King | Quote:
__________________ Harry | |
| | #12 |
| Forum Contributer Supreme Forum King | Roger, as Corey pointed out, I buy the inlays ready made, I know that in a way it's cheating, however I simply lack the artistic talent and patience needed to make my own. But YOU Roger who does this sort of thing on a larger canvas on a daily basis should have little difficulty. Collect a range of veneers, rout a recess of whatever shape you require by the methods that I have shown and cut the required shapes/colours to fit as you would tiles. I think this is what is meant when they say "those who can, do, those who can't, teach"! Good luck to you and do keep us up to date with you're progress.
| | #13 |
| Retired Moderator Supreme Forum King | Thanks Harry, got to run but will look more closely when I get back! Corey |
| | #14 |
| Marine Engineer Forum King | Planing bits- bottom cleaning bits. I've had good results with these, and they aren't too expensive. http://magnate.net/index.cfm?event=s...roup&theID=136
| | #15 |
| Forum Contributer Supreme Forum King | Doug, they look perfect for the job and as I suggested, as cheap as chips over there.
| | #16 |
| Registered User Forum King | Any problems with rods flexing? I used steel rods on my setup few years back and still got flexing.
__________________ router è ancora il mio nome |
| | #17 |
| Forum Contributer Supreme Forum King | As mentioned, my rods are 12mm but I think that 10mm should be OK bearing in mind that you do NOT touch the router itself, all control is from the ends so the leverage that this gives has to be experienced, it is totally different to what you are used to. Perhaps someone like Bj. might hop in and tell me what size hole the most common routers in the USA have, also possibly people in other countries.
| | #18 |
| Registered User Forum Fanatic | Hi Harry, Nice example of the use of the router supports...The guide rods on my Porter Cable 895 router don't go all the way through the base, so I had to make a sub base to allow me to use Tom's router supports, and all of the black spray paint in the world wouldn't make them look as GOOD as yours, but they do work GREAT! I used 1/2" drill rod, but I used clamping blocks on mine instead of threading the ends of the rods, so I am able to adjust the span between the supports to accomodate a smaller working surface with my supports. I have only used them so far for added support when I was using templates and they have really worked out great for that task I'll try to take some pictures of my setup before I go to bed tonight.
__________________ Greg ------------------------------- |
| | #19 |
| Forum Contributer Supreme Forum King | I'm sure that we all look forward to seeing you're photos Greg.
| | #20 |
| Registered User Forum Fanatic | Well it's a bit dark out but I think you can get the idea of my router supports from these pictures... I used Bob's knobs and Niki's non-slip to hold everything together ![]()
| Motorized Router Lift - Eagle Lake Style | johnwnixon | Table-mounted Routing | 10 | 09-13-2007 06:59 AM |
| NEED advice for a simple fence for router table | delirous26 | General Routing | 4 | 08-22-2007 02:18 AM |
| Keep It Simple ??? | Drugstore Cowboy | Lobby | 5 | 07-31-2007 10:01 AM |
| Simple router table | simplenik | Table-mounted Routing | 2 | 09-04-2006 12:38 PM |
| A REALLY simple router table | Occam | Table-mounted Routing | 7 | 11-30-2004 09:41 PM |
