Go Back   Router Forums > Routers > Portable Routing
Portable Routing Discussion area on the Portable Router and its applications. Bob and Rick say, "If the piece is bigger than the router then chances are it should be routed with the portable router."
Thread Tools Display Modes
Old 07-17-2007, 02:48 AM   #11
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
Originally Posted by challagan
Okay Harry, I had a quick look this morning before I had to run off for the office and knew I wanted to look at this closer tonight. Glad I remembered!
The Ski thing really hasn't grabbed me until I seen those pics this morning. Now I can see a use for that one for a guy that doesn't have a planer. How thick was the board before you planed it and how thick after? Can I ask how come you didn't do the other side and is further warping etc. a concern ? Please understand that I am not badgering you on this... I sincerely don't know what to expect and that is why I asked. This intrigues me. Thanks for posting that Harry. I will have to check out those Ski instructions again. I have some box stock that is 3/8 and 1/2 inch that is curved with about a 1/16 off the level surface in the middle of the board so it seems I should be able to do this on both sides to save the stock, even if I end up with 1/4 to 3/8 stock... it will still be more usable then it is now.
The inlay.... That gets me all revved up. That's the kind of thing I want to do more of. I can use my Milescraft Inlay and Spirocrafter to make inlays and or carvings and this is really something I want to do on my boxes in the future. I like what you did on this and that's a neat little jazzed up box. I would have to use my inlay bushing set though or the Milescraft set up!
Thanks for the post Harry and all the pics! BTW, thats how I line my boxes as well. I use 1/8 hardboard on smaller boxes and cover them like that. I use mat board for larger boxes.
Another question, what cutter do you use for the planing operation. Looks like a spiral bit maybe cut wouldn't something flat bottomed like a hinge mortising or dado clean up bit work well for this?
Corey, the board itself was 10.5mm but on a flat surface convex side up it was12.5mm meaning that at least 2mm had to be removed from each side, this would have left a board no more than 6mm thick, a little less than 1/4", too thin really for most projects. I used the curved board especially to demonstrate the ski mounted router in use. I didn't bother planing the inside of the bottom 1..the bottom would have been thin and 2..it can't be seen under the felt! (what the eye can't see, the heart can't grieve) The cutter I used was a 10mm end cutter, that is one with an extra cutting blade on the end, quite expensive here but as cheap as chips in the USA!.I think that the larger the diameter the better and can't see any reason why dado cutters couldn't be used. The question of surface circles has been mentioned,bear in mind that the router is controlled by the ski ends, so no pressure is applied to the router itself so the depth of cut shouldn't vary along the length of cut and going along the grain ensures a smooth finish that only needs two strokes of 600grade paper! If I have forgotten anything, don't hesitate to ask. I'm sorry for the late hour of this post, but blame you're senior moderator who Skyped me as I was about to log on to the forum and when we get talking time stands still!!!!
planing-router-simple-inlays-ski-1.jpg  planing-router-simple-inlays-ski-2.jpg  planing-router-simple-inlays-ski-3.jpg  planing-router-simple-inlays-ski-4.jpg
Harry
harrysin is offline   Top - Reply with Quote
Old 07-17-2007, 04:16 AM   #12
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
Roger, as Corey pointed out, I buy the inlays ready made, I know that in a way it's cheating, however I simply lack the artistic talent and patience needed to make my own. But YOU Roger who does this sort of thing on a larger canvas on a daily basis should have little difficulty. Collect a range of veneers, rout a recess of whatever shape you require by the methods that I have shown and cut the required shapes/colours to fit as you would tiles. I think this is what is meant when they say "those who can, do, those who can't, teach"! Good luck to you and do keep us up to date with you're progress.
Harry
Old 07-17-2007, 06:20 AM   #13
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Thanks Harry, got to run but will look more closely when I get back!
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 07-17-2007, 07:51 AM   #14
kp91
Forum King
kp91's Avatar
First Name: Doug
Planing bits- bottom cleaning bits.
I've had good results with these, and they aren't too expensive.
http://magnate.net/index.cfm?event=s...roup&theID=136
1 John 1:9
kp91 is online now   Top - Reply with Quote
Old 07-17-2007, 11:54 AM   #15
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
Doug, they look perfect for the job and as I suggested, as cheap as chips over there.
Harry
Old 07-17-2007, 11:53 PM   #16
Router is still my name
Forum King
Router is still my name's Avatar
Router is still my name is on a distinguished road
Any problems with rods flexing?
I used steel rods on my setup few years back and still got flexing.
router è ancora il mio nome
Router is still my name is offline   Top - Reply with Quote
Old 07-18-2007, 12:07 AM   #17
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
As mentioned, my rods are 12mm but I think that 10mm should be OK bearing in mind that you do NOT touch the router itself, all control is from the ends so the leverage that this gives has to be experienced, it is totally different to what you are used to.
Perhaps someone like Bj. might hop in and tell me what size hole the most common routers in the USA have, also possibly people in other countries.
Harry
Old 07-18-2007, 12:40 AM   #18
gregW
Forum Fanatic
gregW is on a distinguished road
Hi Harry,
Nice example of the use of the router supports...The guide rods on my Porter Cable 895 router don't go all the way through the base, so I had to make a sub base to allow me to use Tom's router supports, and all of the black spray paint in the world wouldn't make them look as GOOD as yours, but they do work GREAT!
I used 1/2" drill rod, but I used clamping blocks on mine instead of threading the ends of the rods, so I am able to adjust the span between the supports to accomodate a smaller working surface with my supports. I have only used them so far for added support when I was using templates and they have really worked out great for that task
I'll try to take some pictures of my setup before I go to bed tonight.
Greg
gregW is offline   Top - Reply with Quote
Old 07-18-2007, 01:25 AM   #19
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
I'm sure that we all look forward to seeing you're photos Greg.
Harry
Old 07-18-2007, 01:31 AM   #20
gregW
Forum Fanatic
Well it's a bit dark out but I think you can get the idea of my router supports from these pictures...
I used Bob's knobs and Niki's non-slip to hold everything together
planing-router-simple-inlays-support1.jpg  planing-router-simple-inlays-support2.jpg  planing-router-simple-inlays-support3.jpg
Greg
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
NEED advice for a simple fence for router table delirous26 General Routing 4 08-22-2007 03:18 AM
Keep It Simple ??? Drugstore Cowboy Lobby 5 07-31-2007 11:01 AM
Simple router table simplenik Table-mounted Routing 2 09-04-2006 01:38 PM
A REALLY simple router table Occam Table-mounted Routing 7 11-30-2004 10:41 PM
