Go Back   Router Forums > Routers > Portable Routing
Thread Tools Display Modes
Old 09-12-2007, 09:38 AM   #11
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
Joe Lyddon is on a distinguished road
OK, how about a Dremel type tool...
Already assembled?!
... that's a real curve ball...
Good luck.
Joe Lyddon is offline   Top - Reply with Quote
Old 09-14-2007, 11:15 PM   #12
JDługosz
Dedicated Member
JDługosz is on a distinguished road
Here is a photo of the bad rabbet:
(( it did not let me post an image!! How did other people manage it? So paste it together the hard way: the domain is
three w's, the domain name "dlugosz", and the most COMmon top-level-domain with dots added, and the file is "files postings 2007 9 bad_rabbet.jpg" with the spaces replaced by slashes))
The line was scribed before routing.
Since the blowouts are associated with wavy cuts, I think the wobble of the router has a lot to do with it.
My plans are to make a router base that spans the whole box width so it will be steady, yet still be easy to make multiple passes. Clamping edges around would have to be done piecemeal. I'll also take smaller bites in the horizontal direction (start with larger bearings).
Also, thanks for the tip of rabbeting half depth and doing the same for the back panel.
—John
JDługosz is offline   Top - Reply with Quote
Old 09-14-2007, 11:17 PM   #13
JDługosz
Dedicated Member
I have a mini circular saw blade for the Dremel. But I don't have a router-like base for it, and freehanding would not work for me.
I wonder, does anyone make 1/2" router shaft mandrels that can take various Dremel tool disks?
--John
Old 09-15-2007, 08:29 AM   #14
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi John
I tried to find your picture on your web site but didn't find it, here's link to it
http://www.dlugosz.com/
if you fill in the rest of the address in your post it should pop up
or your can do this way
dlugosz.com/bad_rabbet.jpg
just drop the 1st.part of the address
—John
Bj
Old 09-15-2007, 08:34 AM   #15
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi John
Dremel, Yes they do, http://grizzly.com/ but I'm not sure what you mean by "shaft mandrels"
--John
Bj
Old 09-17-2007, 11:16 AM   #16
JDługosz
Dedicated Member
(omitted first parts) dlugosz.com/files/postings/2007/9/bad_rabbet.jpg
Old 09-17-2007, 11:28 AM   #17
JDługosz
Dedicated Member
The Dremel router base isn't for the cordless models. It has a more melted "ergonomic" shape rather than a neat cylinder.
By "1/2 inch router shaft mandrel" I mean a mandrel that fits in a 1/2 inch router collet. But instead of a bit, it would have a screw on the end.
Old 09-17-2007, 11:42 AM   #18
JDługosz
Dedicated Member
Thanks all for the comments.
I got it to work this weekend, by keeping the router level and cutting 1/8" at a time.
Because I was going to make three passes, I didn't want to keep moving and reclamping an edge. I made a router base that was as wide as the cabinet, and bridged the large gap. It worked beautifully.
Also, I went to full depth but changed guide bearings three times, to take 1/8" at a time in that direction.
I still scribed the line first, too.
—John
Old 09-17-2007, 11:53 AM   #19
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi JDługosz
Not that I know about but you can get a Adaptor, then just push in the Dremel tool mandrel into the adaptor...I use it this way when I need to use the SMALL router bits with the 1/8" shanks..the bits are about 1/4 the size of the standard router bits..But I also use the mandrels in my Dremel router table for doing fine work...also and in the Colt router table...
Steel Adaptor Bushings
Part niumber #273 1/2" to 1/8"
http://www.mlcswoodworking.com/shops.../adapbush.html
Bj
Old 11-17-2007, 12:15 PM   #20
Rard
New Member
Rard's Avatar
Rard is on a distinguished road
Mike when you said "use an edge guide with some kind of wood attached" I assume that you mean wood attached or clamped to the outside of the case which would not only keep the edge guide from riding across the cabinet case but would serve as a wider platform for the router to ride on to help keep it square?
The optimist fell ten stories
And at each window bar
He shouted to his friends
All right so far
-Unknown-
Rard is offline   Top - Reply with Quote
Dovetails In Plywood rmaxa Router Bits - Types and Usage 6 12-19-2006 10:00 PM
Rabbeting 3/4" plywood edge WoodenShoe Table-mounted Routing 3 06-13-2006 01:15 PM
Problem with my Hitachi M12V Visteonguy Table-mounted Routing 23 08-18-2005 11:22 PM
elu router problem fretbender Portable Routing 7 03-21-2005 10:35 PM
Hitachi M12V Router Problem dcarriere Tools and Woodworking 3 12-28-2004 06:50 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109
